Home | GE | Dryers
GE DCVH515GF Gas Dryer
Problems with GE DCVH515GF Gas Dryer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for GE DCVH515GF Gas Dryer RSS Feed
Click here to get instant support from our best Experts!
View More Results for GE DCVH515GF Gas Dryer
Questions and Unsolved Support Problems
Unsolved Problems for GE DCVH515GF Gas Dryer RSS Feed
Answer
error E61 appears on digital screen. dryer does not work at all....... help.... resetting has not... (More)
Answer
The dryer starts fine and runs for two minutes, then stops. The digital readout goes from 58 to 00.... (More)
Answer
Cloths do not dry first time is there a reset button after you clean lint out of back discharge?
Answer
Hello, My dryer just displays EO1 All the buttons make a beep sound but nothing happens. It will... (More)
Answer
I just had a new GE Gas Super Capacity dryer installed. One hour after it was delivered I went to... (More)
Answer
My clothes come out extremely wrinkled.
Answer
I checked the breaker and it's fine. The dryer functions but there is no heat. I have gas to the... (More)
Find a Manual
GE DCVH515GF Gas Dryer Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Dryer Runs, but Does not Heat
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the... written by jsrock516
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model... written by jsrock516
How to change your dryer from 3 wire to a 4 wire power cord. (short and...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power... written by MNTECH
Washer and Dryer Repair manuals and Parts
Please rate a Fix Ya!!! Thanks jj505 For all Washers/Dryers/Parts http://laundry.manualsonline.com/ written by jj505
Possiable Manuel HELP OR ORDER PARTS LINK
Please rate a Fix Ya!!n Thanks jj505 http://www.repairclinic.com/Home.aspx written by jj505
SAVING TIME & MONEY $$$
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if... written by DRRXR
Dryer operates but will not heat.
1. Disconnect electrical power to dryer. 2. Remove the lid. 3.On the front panel there is a circuit board (moisture sensor control board) with a six... written by gregorymholt
3-prong to 4-prong Power Cord Conversion.
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards). 3-Prong or 4-Prong ?... written by jsrock516
WikiManual
(Post a New Chapter)
How to Clean a Clothes Dryer Vent
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean... by wikihow
How to Wire an Electric Dryer
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected... by wikihow
How to Improve the Lifespan of your Clothes Dryer
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the... by wikihow
How to Repair Loose Baffles in Your Dryer Tumbler
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about... by wikihow
How to Prevent the Dryer Cord and Terminal Block from Burning Out
Tips on how to prevent the dryer cord and terminal block from burning out. Steps 1. The cause of the dryer cord wires and the terminal block for... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for DCVH515GF Gas Dryer
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
Nationwide | 7606873360 | Website
Washer and Dryer repair specialists. Why hire som... Read More
Nationwide | 312-404-7574 | Website
Our focus will always be to provide top-notch qua... Read More
Find an Expert
Meet our 2937 Dryer Experts
emissionwiz
Rank: GuruGuru
Rating:  90%, 8109 votes
Solutions:  14762 (916 Votes in the last 30 days)
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
dmftrucker
Rank: GuruGuru
Washers & Dryers ExpertExpert
Rating:  87%, 406 votes
Solutions:  1582 (474 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
slosmogman
Rank: GuruGuru
Rating:  86%, 287 votes
Solutions:  1104 (466 Votes in the last 30 days)
Experience: ASE Smog Technician Advanced Engine Performance General Handyman
projdoc
#4: projdoc
Rank: GuruGuru
Rating:  94%, 604 votes
Solutions:  1178 (449 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
justaskjoe
Rank: GuruGuru
Rating:  85%, 1994 votes
Solutions:  3866 (365 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
hunter19_46m
Rank: GuruGuru
Rating:  92%, 159 votes
Solutions:  751 (325 Votes in the last 30 days)
Experience: I have worked on many electric dryers in my working career. I am also mechanically inclined.
localwonder
Rank: GuruGuru
Rating:  92%, 2780 votes
Solutions:  4911 (320 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
avid101
#8: avid101 Expert Moderator
Rank: GuruGuru
Rating:  87%, 1145 votes
Solutions:  2442 (312 Votes in the last 30 days)
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
57 varieties
Rank: GuruGuru
Rating:  88%, 519 votes
Solutions:  1495 (302 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
techbuster
#10: techbuster
Rank: GuruGuru
Rating:  89%, 494 votes
Solutions:  1107 (270 Votes in the last 30 days)
Find a Warranty
Specifications for GE DCVH515GF Gas Dryer
Key Features
Design
Free-Standing
Power Source
Gas
Load Type
Front Loader
Dryer Type
Home Dryer
Stackable
Stackable
Other Features
Cycles
15 Cycles
Cool Down Feature
With Cool Down Feature
Quiet Mode
With Quiet Mode
Moisture-Sensor
With Moisture-Sensor
Dimensions
Overall Depth
31.13 in.
Overall Height
41.5 in.
Overall Width (Display)
27 in.
Warranty
Warranty
1 Year
GE Contact Information
Main support number1-800-626-2005
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
