20 Most Recent
Sharp AR-M355U Copier Questions & Answers
I am getting error code
L4-02 - Drum Motor Lock.
- Remove the process unit, remove the drum & check the waste toner
auger & gear assembly.
- You will probably find this is seized or broken
due to excessive drum cleaning.
- When changing the drum & developer,
you must reset the rotation counters as well as the drum/dev counters. Otherwise, there is excessive over-toning, leading to waste toner
filling the toner cartridge waste area too quickly & therefore
leading to waste toner auger assembly blocking up.
- You will probably need a new process unit as the auger drive gear has been known to break off the frame.
- There is new firmware for this problem. Have a service professional update the firmware for this device and the problem will be gone.
I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Drivers windows 7 64
http://www.sharp-idncservice.com/DesktopModules/SharpDriver/SDdlViewFile.aspx?IDFile=14335&file=Windows%2064bit%20OS%20Print%20Driver%20Package%20for%20Jupiter.zip&location=\\secnas\msgwebprod\Content\Index\idncservice\DriverFiles\Windows%2064bit%20OS%20Print%20Driver%20Package%20for%20Jupiter.zip&From=SharpUSA I’m happy to help further over the phone at
https://www.6ya.com/expert/ethan_e84416e0b13809d2
When I open my copy
H4
error is heat roller under temperature, try pressing the "#" key then
"Interrupt" key then "C" key then "Interrupt" key to get into
simulation mode and enter 14 and press start the follow instructions on
screen (should be press ok). This will reset the code and restart the
machine. When the machine restarts if the error was not mechanical the
machine should go. If not you have one of two most likely problems; you
need to reset the thermal cut-outs on the fuser unit or the fuser
lamp is blown.
The display says that the
Shut the machine off, unplug the finisher from the copier, then plug it back in. Make sure the finisher is securely attached to the machine, then turn the machine back on. If that doesn't work, remove the finisher completely and use the machine without. Call a service technician to diagnose your finisher problem.
We have a Sharp AR-M355U copy machine that we are
Sim 62-1 will reformat the hard drive if there is one. On the key pad press POUND-STAR-CLEAR-STAR and enter SIM 62 copy button 1 copy button. If you cant get into sim 62 there is no hard drive. If you can get into sim 62-1 then follow the display press yes. and that will reformat your harddrive.
We are getting a code H5-01 what does this
H5-01 means there were five consecutive jams at the fuser section. Open the left jam door and look up in the fuser (heat) section and at the top of it You should find sheets crunched into an accordian After clearing all the paper from this area close up the copier Turn it on and press the copy mode key Then the following keys in order one after the other Program..*..C..* The display will change to service mode input 14 then the copy start key enter 1 for yes then the copy start key if the copier does not restart itself then hit the CA key the copier sholr reset and start with out the code
