20 Most Recent Samsung Ln40e550 40 1080p Lcd Tv ln40e550 Questions & Answers
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Samsung Ln40e550... | Answered on Jul 30, 2016
Hello, this set has only a USB jack that can be used for audio output, but that is the only output on this set. If your receiver doesn't have a USB jack, the satellite box output is your only solution. thanks,Terry
Samsung Ln40e550... | Answered on Oct 11, 2012
The problem is the LCD panel went bad, it can't be repaired, you have to replace it.
Samsung LN... | Answered on Jan 16, 2018
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung LN... | Answered on Nov 18, 2016
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
Samsung LN... | Answered on Mar 17, 2016
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Samsung LN... | Answered on Jan 18, 2016
Could be power supply failure. It tries to start but can't.
Samsung LN... | Answered on May 16, 2015
flicking or shutting down,i have the same tv,mine shuts down,it needs power supply,yours needs the control board,get one on ebay
Samsung LN... | Answered on May 11, 2015
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Samsung LN... | Answered on Mar 15, 2015
Page 64 of the user manual explains this procedure.
Go to Global Download Center and under Manuals, click See More + and then click on Download PDF.
Samsung LN... | Answered on Mar 03, 2015
Hi, not sure if you have the same fault as i had, but our tv only had half the screen go off, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
Samsung LN... | Answered on Mar 01, 2015
You can also replace the bad capacitors on the power supply board.
Samsung LN... | Answered on Jan 27, 2015
Sounds like the LCD Panel, if under warranty contact Samsung warranty for service. If out of warranty, watch it until you tire of it then replace the unit as the cost of a new panel is more than a new unit.
Samsung LN... | Answered on Jan 03, 2015
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/ .In most cases, the main board might have to be replaced.If so, a software [firmware] update too might be necessary.
Samsung LN... | Answered on Sep 30, 2014
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Samsung LN... | Answered on Aug 24, 2014
Contact your insurance company and make a claim. Lightning damage to electronics like that is hard to repair.
Samsung LN... | Answered on Aug 07, 2014
Samsung Ln40e550 40 1080p Lcd Tv ln40e550 Logo
3 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
hook up surround sound
  • Televison & Video
