20 Most Recent Vtech T2326 Cordless Phone Questions & Answers
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Vtech T2326... | Answered on Mar 13, 2016
The manual is available for free download from www.manualslib.com
A Google search on "vtech t2326 manual" will take you right there .... follow their site instructions,
enter the "spam protect" numbers and choose "download the .pdf file" Be careful of clicking on the
advertising that might take you into strange areas for other purposes.
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: 1" ( or "RINGER: 2 or : 3 or : 4 or : OFF" )
10. ...and so on, cycling through the four choices: when you decide to select one, press the "SELECT" end
11. The display light will go out, the phone will chirp in acceptance, and be ready to use the chosen ringer. --
To preload names & numbers into the DIRECTORY is a bit more arduous but not difficult; there is
a limit of 10 entries after which attempting to add another will result in a "MEMORY FULL" alert
being shown. Hint: during name entry, the "VOL -/CID" button will backspace/erase letters and the
"VOL +/DIR" button will enter blank spaces. Letter selection is familiar to text messaging ie, the letter B
is a result of "22" being keyed, the letter R is "777" etc.
Good luck !
You can download the manual here.
Vtech T2326... | Answered on Jan 24, 2012
With the handset in idle (off) mode, press PROG.
Press down-arrow until the screen displays RINGER: and the current setting.
Press SELECT. The current setting blinks, and you will hear a sample of the ring.
Press up-arrow or down-arrow to select RINGER: 1, 2, 3, 4 or OFF. You will hear a sample of each ring tone.
Press SELECT.
If you need a manual, you can download one here.
Vtech T2326... | Answered on Oct 18, 2011
There's nothing about voicemail in the manual since the T2326 isn't an answering machine. If you're subscribed to a voicemail system offered by your phone company, contact them for instructions. If you have a separate answering machine connected to your phone line, consult its documentation.
Vtech T2326... | Answered on Oct 16, 2011
The T2326 isn't an answering machine. If you have an answering machine connected to your phone line, consult its documentation. If you subscribe to a voicemail system offered by your telephone company, contact them for information and help.
Vtech T2326... | Answered on Sep 23, 2011
Your phone service provider is sending a signal on your phone line that is activating the message waiting on your phone. Likewise the beep-beep-beep you hear is called stutter dail tone which is sent by your phone service provider to indicate that you have a message in voicemail for phones that do not have message waiting or message waiting light ability. To cancel the message indicators, you'll need to call your phone service provider customer support and have them disable voicemail. Nowadays, voicemail service is often automatically added by service providers, especailly if you have recently changed service providers or your service provider has upgraded their switch equipment.
Vtech T2326... | Answered on Mar 15, 2011
I wouldn't recommend disassembling it.
One common solution to dry out the phone is to put it in your oven. Preheat your oven to the lowest setting, normally ~180 degrees. After it's done preheating, turn it off and wait for about 15-20 minutes. Then place your phone inside your oven and close the door.
The temperature by waiting will decrease to around 150 or less, which won't melt the plastic case, but will give enough heat to dry out the phone. Leave it in there for an hour or so, then see if it's dry.
Before you do it, remove the battery and battery cover from the phone. This will give the moisture somewhere to escape, and reduce your risk of damage to the battery pack.
Vtech T2326... | Answered on Jun 11, 2010
call to voice mail number
for voice mail number ask your service provider
Vtech T2326... | Answered on Nov 26, 2009
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=21709
try this link its for the VTECH t2326 manual, hope this helps, kep me posted
Vtech T2326... | Answered on May 25, 2009
Here it is........
mtg
Vtech T2326... | Answered on Apr 11, 2009
Vtech phones namely model cs6729-37.. the worst! You can't see who is calling and you cannot adjust screen brightness. Answer? Buy another phone! I got a panasonic -- same thing -- smaller profile -- 3 phones wireless back to the main base.. and they take AAA's not special batteries. The Vtech has given me hours of aggravation trying anything to get it brighter -- you can't. Don't waste your time and don't buy one -- Panasonic you can at least see who is calling. Why did V-Tech decide to make the LCD screen unreadable? I don't know and I don't care. What a waste of time and money. It's been miserable owning the V-Tech 3 phone system and I should have thrown it out sooner.
Vtech Lands... | Answered on Sep 03, 2019
Vtech T2326 Cordless Phone Logo
23 questions posted
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Vtech Lands Phones
  • Vtech Lands Phones
Most Popular Question
program numbers lost owners manual
  • Lands Phones
