20 Most Recent Friedrich QuietMaster Electronic SS12J10AR Air Conditioner Questions & Answers
Replacement cord for Friedrich SS12J10R-1 a/c unit how to
drawing to many amps. something shorted to ground.
9/14/2015 8:32:42 PM • Friedrich... • Answered on Sep 14, 2015
Water is draining into my
Before you buy another one, check two things:
1. make sure the unit is tilted back in the window and not forward. The unit has to be tilted back away from the window about a half bubble on a level in order to drain out the back.
2. if the unit is tilted in the window properly and still draining out the front, you will have to take the case off the unit and wash it out good with a hose and sprayer. If the unit is not rusted out on the bottom, the drain is stopped up that drains the water from the front coil into the base of the unit. The water should be draining from the front to the back, and excess drains outside on the ground. Hopefully, it just needs a good cleaning. Hope this can save you from buying a new unit. Stay cool. Mark
7/10/2011 11:32:06 PM • Friedrich... • Answered on Jul 10, 2011
Model SM14J10B-1. Put back
Could you please confirm that it is showing F4, Errors on Friedrich Air Conditioners are E*.
F4 would normally relate the the Fan Speed as High, can you try and change the Fan Speed.
5/27/2011 8:10:06 PM • Friedrich... • Answered on May 27, 2011
2answers
Friedrich Model MR36TQY3JMA mini split. The Inside units have white LEDs. The Heating LED blinks 4 times. The Cooling LED blinks 3 times. Repeat. Nothing else happens. Any thoughts?
A Power Reset will fix most things. Turn off the power at the breaker for a couple of hours. It resets the main board and all the relays. Service Manuals in the link https://www.google.com/search?q=Friedrich+Model+MR36TQY3JMA+mini+split+blinking+codes ..
3/15/2023 4:28:50 AM • Friedrich... • Answered on Mar 15, 2023
How do i turn off check filter light on friedrich model KCM14A10A throughn the wall unit
Press fan and speed together for 3 seconds
8/24/2021 5:07:48 PM • Friedrich... • Answered on Aug 24, 2021
Friedrich through wall unit pdh12k35G-A has error code on display A2. Chart says heater malfunction protection. Wtf am i looking for?
heating switch over or unit failure --circuit or conrtol failure
3/31/2020 11:33:10 AM • Friedrich... • Answered on Mar 31, 2020
I have a friedrich cp15f10 unit and it was tripping the breaker on and off for about 3 weeks. Yesterday It tripped, I reset the breaker but no power on the unit. It produced very cold air and I always had it on low. Does anybody know what it could be?
That's what happens with loose electric connections. Need to go from the breaker to the AC unit power run inspecting each wire splice, all electric connections need to be clean and tight.
A loose connection becomes electrical resistance and electrical resistance consumes power, power consumed is dissipated as heat. Overheated, charred, discolored connections can be cut off and reconnected when found.
Start by tightening the circuit breaker wires, and neutral if any.
7/23/2019 11:05:17 PM • Friedrich... • Answered on Jul 23, 2019
Friedrich QuietMaster Electronic SS12J10AR Air Conditioner Logo
7 questions posted
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Jay Finke
Jay Finke
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Friedrich Heating & Cooling
Most Popular Question
water draining into
  • Heating & Cooling
