20 Most Recent
Epson CX3810 Stylus Color All-In-One Printer Questions & Answers
How to reset the printer
Almost any printer produced since the R320 came online has had the ability to use buttons on the printer for resetting, etc... removed... It simply doesn't work.
Instead you usually need a reset utility which is the case for the CX3810.
A link and all the related information for the CX3810 is available via the
quickfind tool I have on OctoInkjet and in this case you need and can download the A10_IPR tool that Epson released for North American customers a few years back.
Hope that helps.
Martin
I dont have the cd to install
Hello, here is the Support link that you need.. Please, if you can enter a testimonial for my solution, it will make my chance for our contest greater.. I would Very Much Appreciate it. Thank You
Not printing clearly
You should run a nozzle check to verify if the heads are printing all
the inks correctly. If the pattern is incomplete you need to run head
cleanings.
I replaced my ink cartridges
You sound like you have a corrupt driver. Sadly they get corrupt for reasons that are unknown. Sometimes the least little thing will set them off.
Here is the quick and sure CURE:
http://www.youtube.com/watch?v=3QxK5J3MCSo&feature=related
While the link in you tube tutorial is for a video card - just substitute PRINTER - - for the VIDEO - -
Once the driver is deleted - reboot and this is when your pc will put the correct - uncorrupted Printer Driver in.
Can I setup wireless printing for epsoncx3810?
hi there..
yes you can but since this is not a wifi ready printer,. you can only do that thru printer sharing, and that means you can only print over the network but scan wont work.
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
How do i get my epson cx3810 to scan
you need to open the paint for open it , click on "start/all programs.accessories/paint".
when it's open click on the file and and select the option "scanner and camea wizard" and click on it.
after that a new scan windows will appear there, click on the scan without made any chage and once when scan get complete save the scan file.
Printing Question
are the epson ARC chipsets available on office depot or big retailers?
Language
If you go to this link, you can download the english language drivers for your printer and scanner;
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=60421&prodoid=56291069&infoType=Downloads&platform=Windows
and also the user manual etc.
You probably have to uninstall the french version first before installing the english one, but make sure it downloads first in case there is a problem.
Hope this helps, if not - ask again :)
