20 Most Recent
Epson Stylus CX7800 Color Flatbed All-in-One Printer Questions & Answers
E-04 Clear Paper Jam, no paper in printer
- Turn off the printer.
- Remove any paper trays. Inspect them for wrinkled or damaged paper.
- Also open the back cover of the printer if this model has one.
- Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
- If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
- If you find a piece of jammed paper, remove it by
holding it with both hands and pulling firmly. The goal is to keep the
paper from tearing. If several pieces are jammed together, try pulling
out the middle piece first to loosen the jam.
- If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
- Ones the printer is free of paper Replace the toner or
ink cartridge and paper trays, close any doors you opened and turn the
printer back on.
- If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
- see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
Color priting problem
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
I want to scan a photo on epson cx7800 to an email. Also the photo needs to be rotated
you need a photo program like KODAK to publish this to your job site or Microsoft picture publisher. Open the photo program you have --find the 'GET pictures" or load pictures from your scanner. place them in your 'MY Pictures' file on your computer. you will need to resize the picture to a JPG. as this will make the picture smaller in order to send it. Place the picture on your desktop as a shortcut .
when you go to your job site, you wish to send the resume to--you need to attach the jpg. along with the resume..when you get the 'browse' look for your desktop shortcut and click on it. it should place the picture on the bottom of the resume.
Epson cx7800 printer-lost software
I don't know of anywhere you can buy just the software except from epson directly. You can try to download the software from their website for free. The link to your specific printer's page is
HERE.
If you have trouble deciding which driver to download, please provide me with your Operating System and I will help further.
Scanning lamp
lamp is busted, better check your date of purchase for warranty.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link
http://www.epson.com/loyalty .
EPSON STYLUS RX 520 HAS AN ERROR E-91
The error E-91 on an Epson Stylus RX 520 indicates a communication problem between the printer and the cartridge. Here are some steps you can try to resolve the issue:
- Turn off the printer and unplug it from the power source.
- Remove all the ink cartridges and check for any damage or leaks. Replace any damaged or leaking cartridges.
- Clean the metal contacts on the ink cartridges and inside the printer with a soft, lint-free cloth. Make sure they are completely dry before reinserting the cartridges.
- Reinstall the ink cartridges and make sure they are properly seated.
- Turn on the printer and see if the error message still appears.
If the error message persists, try resetting the printer by following these steps:
- Hold down the "Stop" and "B&W" buttons while plugging in the power cord.
- Keep holding the buttons until the printer starts to initialize.
- Release the buttons and wait for the printer to finish initializing.
- Try printing again to see if the error message is resolved.
If none of these steps work, there may be a hardware issue with the printer and it may need to be serviced by a professional technician.
HOW TO RESET THE COUNTER ON MY EPSON STYLUS SX415
Please attempt to factory reset your printer in order to reset the counter. If you don't know how to do this, please check the table of contents in your device's manual: https://www.manualslib.com/products/Epson-Stylus-Sx415-4234082.html . Thank you.
