20 Most Recent
Dell 810 All-In-One InkJet Printer Questions & Answers
How to change printer cartridge Dell 810
Open the printer cover with it turned on and connected to your pc. When you open the cover, the printer should bring the ink cartridge carrier to the front and center so you can access cartridges easily. Press or pull the plastic tab next to the ink cartridge that you wish to replace and it will pop it up towards you and out of the carriage. if there is no plastic tab to eject the cartridge, grab a hold of it with your finger and pull upward and out towards you. Don't worry about breaking anything or harming the cartridge. Once you remove the old one, remove the plastic tape tab on the new cartridge before inserting. Then close the printer cover and it should walk you through aligning the print heads on the display. Good luck!
11/4/2019 9:37:35 AM •
Dell 810...
Answered
on Nov 04, 2019
Will not power on.
it might be the power supply board itself ,either fuse or the condenser is burned.
4/17/2016 5:55:01 PM •
Dell 810...
Answered
on Apr 17, 2016
PAPER JAM
When the paper goes it on the inside of the printer grabs both side which what feeds it through, if it is not tight enough will cause paper jams, open it back up and check the roller to see if it can be adjusted if it cant then you will need to buy a new one, this usualy happens when it has had too many paper jams forcing the gap to increase in size and not allow the collection of one but many, on single sheets of paper the gap wont be small enough to collect 1 sheet anymore.
7/10/2015 10:08:08 PM •
Dell 810...
Answered
on Jul 10, 2015
I got a new computer and it does not have the
Just copy and paste.
Hope this helps.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_ALL_A810&os=WW1&osl=en&catid=&impid=
3/3/2015 11:31:55 AM •
Dell 810...
Answered
on Mar 03, 2015
Does the tell 810 all in one printer come with a usb?
Yes this printer should come with a USB cable because that's the only way you can use it , so if this unit is new better go back to the store where you purchased it and ask them about the USB cable so they can replace it....
4/19/2013 9:02:22 AM •
Dell 810...
Answered
on Apr 19, 2013
My dell 810 all in one will scan but will not
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.? PLEASE TRY NOW !
6/29/2012 7:00:48 PM •
Dell 810...
Answered
on Jun 29, 2012
Will not work with windows 7
Hi Loretta,Have you installed compatible[Windows 7 OS] printer drivers in your new PC?If not uninstall the already installed drivers and install new drivers from this
Dell support site. Also make sure you properly connect the printer with the PC.Hope this helps.Thanks!Please rate this answer.
11/24/2011 7:03:19 PM •
Dell 810...
Answered
on Nov 24, 2011
