Honeywell HZ708 Oil Filled Radiator Heater
Problems with Honeywell HZ708 Oil Filled Radiator Heater?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Honeywell HZ708 Oil Filled Radiator...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Honeywell HZ708 Oil Filled Radiator Heater RSS Feed
View More Results for Honeywell HZ708 Oil Filled Radiator Heater
Questions and Unsolved Support Problems
Unsolved Problems for Honeywell HZ708 Oil Filled Radiator Heater RSS Feed
Answer
When I press the on button, an F appears on the display. It stays on for about 5 seconds and then... (More)
Answer
I have a HZ-708 oil filled heater that I accidentally knocked over and now it doesn't work at... (More)
Answer
My portable oil heater is making a bad smell, like melting wax. I have turned it off and unplugged... (More)
Answer
the one on the right sets the temp, the one in the center shows a clock and can be set between 1 and... (More)
Answer
I have a Honeywell HZ709 electronic oil-filled radiator heater. It's a black model. I can't find the... (More)
Answer
Digital display shows only 999 and controls to move temp up or down don't work at all. I am told by... (More)
Find a Manual
Honeywell HZ708 Oil Filled Radiator Heater Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
The extra benefit of a Modulating Boiler
You're looking to install a new hot water boiler or replace your existing boiler. You come across something called a "modulating" boiler.... written by heatman101
Boiler Aquastat - How to set it
It is the coldest day of the year and your boiler is chugging along. However you notice that your house is slowly cooling off even though the boiler... written by heatman101
Carbon Monoxide and Heating Systems
Every year there are many deaths that could be avoided by a few simple checks, or the addition of a carbon monoxide detector in the home. The worst... written by heatman101
Outdoor Wood Stove Hot Air or Hot Water
You're getting a new wood stove and you have many decisions to make. Other than brand, you need to decide whether you will use hot air or hot water to... written by heatman101
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass... written by heatman101
Renting and Paying the Gas Bill
This past week I changed out an old hot air furnace in a rental unit that made me question why the tenant did not go to the owner and offer to pay... written by heatman101
Furnace Lockout
Find and remove the flame sensor. Clean the residue off of it with a dry brillo pad. Reinstall it and retry: written by TheMobilian
Williams Wall heater
The Williams wall heater uses a 2 wire low voltage thermostat mounted on wall. If that thermostat should ever have no continuity while in the... written by TheMobilian
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for HZ708 Oil Filled Radiator Heater
Nationwide | 8009059506 | Website
Traditional water heaters use a storage tank to hol... Read More
Featured Listing
Nationwide | 8884489872 | Website
Nationwide plumbers where ever you need us any tim... Read More
Featured Listing
Nationwide | 866 3278928
Ratings for the Honeywell HZ708 Oil Filled Radiator Heater
Owners Recommend
out of 2
Reliability
Ease of use
Value for Money
Find a Warranty
Specifications for Honeywell HZ708 Oil Filled Radiator Heater
Key Features
Type
Radiator
Features
Thermostat, Power Indicator, Wheels
Power Source
Electric
Heating Element
Oil Filled
Heating Levels
3 Levels
Fan Forced
Non Fan Forced
Safety Features
Safety Features
Tilt Switch
Power
Power
600 - 1,500 Watt
Warranty
Warranty
5 Years
Honeywell Contact Information
Main support number800-328-5111
Describe your problem:
Top Heaters Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
