Technical Support, Instructions, Repair Service & Recommendations *New*
Coleman Patio Heater
Problems with Coleman Patio Heater?
Ask our Experts
Ask
Get a Professional
Find a Solution
Troubleshooting and Support
Solved Problems for Coleman Patio Heater RSS Feed Post a New Problem
Ignition doesn't spark any more, no...
I have a  3 year old patio heater/light, propane fueled. The ignition doesn't spark any more, no...
1 Solution
pump not woking
I draind my hot tub and refilled it and now the pumpis not working .I can hear it running put the water is not coming...
1 Solution
Charmglow Patio Heater
My pilot flame will stay on as long as I keep the gasflow valve depressed, but as soon as I let go..the pilot...
1 Solution
charmglow gas patio heater
our patio heater is a little over a year old. It will not turn on. when you push the ignition switch you get a loud...
1 Solution
Charmglow tabletop heater: how do I...
Flame burns yellow constantly. How do I access the air tube at the burner? Does the dome come off?
1 Solution
stopped heating, where is the heating...
our coleman hot tub stopped heating, I drained the tub, put clean water in it and put a new filter in it, also. will not...
1 Solution
1 Solution
Unsolved Support Problems
Unsolved Problems for Coleman Patio Heater RSS Feed Post a New Problem
haven't used for a long time ; light...
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve problem ?
Post a Solution
Can't unlock the control panel
How do I unlock the contol panel on a Coleman 450 hot tub?
Post a Solution
After 3 to 5 minutes the burner will go...
I have a Charmglow outdoor heater,the burner will relight after 5 to 10 attempts, it will run for 3 to 5 minutes and go...
Post a Solution
i have a wall mount in my living room the
i have a wall mount in my living room the thermocouple was replaced and wen it gets up to room temp and shuts down the...
Post a Solution
patio heater wont light
I have a charmglow patio heater that won't light.  Help.  I also see they don't stay lighted.  What do I...
Post a Solution
Charmglow table top patio heater will not...
I've cleaned the pilot light port. The ignition spark appears to work well. When propane does build up inside the unit...
Post a Solution
regulator may be bad; not enough gas...
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with a slight hissing...
Post a Solution
Tips & Tricks
Post a New Tip
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
TypePatio
Power SourceGas
Safety Features
Safety Features100% Burner Shut-Off, Tilt Switch, Automatic Shut-Off
Power
BTU40,000 BTU
Dimensions
Weight111 lb.
Warranty
Warranty7 Years
Coleman Contact Information
Main support number1-800-835-3278
Email supportconsumerservice@coleman.com
Sponsored Links
Describe your problem:
Top Heater Experts
Rank: Guru Guru
Solutions: 684
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
