Troubleshooting & Support
Hot Topics:
- manual
- lights flashing
- driver mac os
- yellow blinking...
- drivers
- reset
- clean paper...
- won print
- driver
- yellow light
- print test page
- usb
- clear paper jam
- clean print...
- slams left
- user guide
- download
- print test
- blinking lights
- ink light...
- IBM
- yellow
- printing
- free
- ink cartridge...
- windows not...
- won print black
- paper feed
- paper not feed
- paper
- View All »
Problems & Solutions
i have a deskjet
The short answer..Yes, with difficulty.. please find below a set of drivers for the mac OS ...
HP printer , will not print
aasc - As I recall from some time ago, HP experimented with putting expiration codes (chips) into some of their printer cartridges in an...
Printer Won't Print
I had the same problem all you have to do is in the left side there is a black sorta arrow looking piece. You have to get this back in...
HP DeskJet 820Cse printer problem
You could try cleaning the rollers with some soap and water. Make sure the power is off first.
HP DeskJet 820Cse Problem
I had the same problem with my 820. The actuator arm is out of place. Do a search for actuator arm and 820 or follow this link ...
IBM Flat Bed Scanner
Andy, the scanner is an IBM scanner? Did you check to see if they have WK2 drivers? Sony said they had no drivers for XP, but would not...
Printer does not pick up paper to print.
The rollers may be dirty and slipping. I just fixed this problem on my old HP 820Cse by cleaning the three rollers with rubbing alcohol...
I connected to my HP DeskJet 820Cse via my home
The 820 is a really old piece of kit and i am very surprised that windows 7 has found a driver for it. I I suspect that it has used a...
my printer will not do color it comes out purple
Try Cleaning the Cartridges manually and automatically. For the cartridge clean it with a damp lint free cloth and also for the...
Removed empty color ink cartridge. Replaced with
Sometimes even new cartridges can fail even more so if the cartridge was refilled.If you haven't already, remove...
I have an HP 820Cse printer. It has fresh
Hello and Welcome to FixYa! The yellow Resume blinking light refers to one of these issues; The top cover of the printer is open or the...
printer tried to take half of the stack of paper
Unlatch and pull out the paper tray. Try pulling out the sheets in the middle of the "half stack" first. You should have less...
where can I buy HP 820sce printer cord with usb
Hi, Any HP inkjet USB cable will fit your printer. You can buy it online from HP shopping site....
I have an HP 820c printer that had a paper jam.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to...
The color yellow does not print., both color and
Make sure the color nozzels are clean, sometimes the get clogged.
Unsolved Problems
Does not print
Window XP Printer Test Page said that my printer 820Cse has correcty installed on my computer and also say...
deskJet 820Cse cartridges thunking on left side...
removed and reinstalled paper tray but the cartridges continue to move left to right and thunk on the left side; yellow...
I just refilled the black ink in my HP...
the sheets were getting faded, so I refilled the ink reservoir. Once I reinstalled the cartridge, the print head...
I just installed a brand
I just installed a brand new HP deskjet 820cse color cartridge. Now it won't print yellow, so all the colors I...
When I start printing something
When I start printing something the printer stops printing it and the power light keeps blinking? what does that mean?
A minha impressora nem liga, apos colocar o plug
A minha impressora nem liga, apos colocar o plug na tomada ela nem acende (nenhum dos leds)\r\nObrigado Xavier/recife
Not able to print two pages, or when I do the
Not able to print two pages, or when I do the second page causes the printer to jam up.
Just changed ink and now won't print. Ink like
Just changed ink and now won't print. Ink like continues to blink on my HP DeskJet 820 Cse printer.
Upload a manual for HP DeskJet 820Cse Printer
What's your problem?
Fix-O-Meter
5,356
5,356 people have viewed this product
- 80 people asked about this product.
- 30 people found solutions for this product.
- 0 people have added this product. Be the first!
How to resolve...
Getting help...
Printer reset
