20 Most Recent HP Photosmart 7660v InkJet Printer Questions & Answers
Please refer to the following article for a detailed step-by-step guide on printing 4x6 photos using this printer model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00038857&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=373433
HP Photosmart... | Answered on Dec 17, 2010
open the lid ,look behind the cross bar, you can find a clear plastic strip,that is a sensor use rubbing alcohal to clean up should take care your problem
HP Photosmart... | Answered on Dec 06, 2008
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
HP Photosmart... | Answered on Aug 12, 2008
i had turn off the main switch without putting off the printer first when i put it on it doesn't respond. now ,i'ts not working anymore.
HP Photosmart... | Answered on Mar 06, 2008
You are in luck. I am here to save the day. Have you tried new ink cartridges?
HP PhotoSmart... | Answered on May 31, 2019
Tip
How to Clear error code 0XC19a0037 Ink System Failure on HP Photosmart Printers
This fix will work on all HP Photosmart printers that use 4 cartridges or 5 cartridge #564 or #364 ink cartridges:
on Feb 05, 2019 | HP PhotoSmart Office Equipment &...
if you want help regarding any type of issue in Comcast email then i would recommend you to take help from Xfinity email support team.
visit: https://www.xfinity.com/support/articles/ways-to-get-help
Comcast Email Customer Services 1 888 211 0387 Technical Support
HP PhotoSmart... | Answered on Aug 04, 2018
Hello download the driver here:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=4023244
By selecting the a or b model.
Next select your windows system and download the driver.
Unplug the usb cable when you install the software and connect it again when the installation program tells you to.
Good luck
HP PhotoSmart... | Answered on Feb 17, 2018
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
HP PhotoSmart... | Answered on Jan 02, 2018
HP Photosmart 7660v InkJet Printer Logo
5 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
hp 7660 print cartridge cradle stuck
  • Office Equipment & Supplies
