20 Most Recent
HP DesignJet 2000cp InkJet Printer Questions & Answers
Hp designjet 2000cp code 050000 00180516 help us .
05000, on the 2000cp is the printer can not find the mark encoder, inside your printer there is a roller running left to right that the media will sit on,
on the far left side were the roller ends there is a small piece of white plastic that should sit in the vertical position. the sensor on the carriage is not able to find this.
Once you see it, clean with a q-tip, slightly dampened, and also change the lens on the carriage.
Power on the printer when finished and see if it will go to the ready status,
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
How to change ip address on hp 5500ps
There are three ways of configuring IP address on any HP Printer:
A.- Using the control panel
B.- Using the web server
C.- Using the Jet Admin Utility
We'll deal with the contro panel setup.
To access the contro panel menus
1. Press OK (Check Mark) button once to access MENUS.
2. Press Up Arrow or Down Arrow buttons to navigate the listings.
3. Press OK (Check Mark) button to select the appropriate option.
4. Press Return to return to the previous level.
5. Press OK (Check Mark) button to exit the menus
So to configure IP address:
Press Check Mark
Navigate to the CONFIGURE DEVICE Menu using Down Arrow (the menu scrolls, so you may use any combination of Up/Down arrows)
Navigate to the I/O Menu
Navigate to the EIO 1 menu
Navigate to TCP/IP
Navigate to BootP entry
Press Check to disable it (Off)
Press return
Navigate to IP Address, press Check
Use Up/Down buttons to change the address, check to move between octets.
When finished, press Return
In the same way, enter Mask and Default Gateway
Press Return until you are out of the Menus.
Done
I need to replace the fuse in an HP Designjet 350C. How?
there are a few fuses that are component based I.E. soldered to the circuit rather than a glass shaped fuse, I would recommend that if you have tried a second mains lead that you put a call into a hp representative or HP trained technician to see if its safe to just replace the fuse or if anything more has happened to cause the fuse to trip.
wildly replacing fuses may cause more harm than good.
the right choice is to have a trained tech called out.
