20 Most Recent
Jura Capresso H2O Plus 259 Cordless Electric Kettle Questions & Answers
My kettle heats water to
I think your kettle is having a switch problem. The switch is failing that is why it turns off and on by itself.
Also, there might be some sort of partial contact in the kettle which is causing it to connect and disconnect at interval. Heat from the kettle can cause wire(s) to melt....
You will have to get a Philip screw driver, open the part of the kettle where the power wire enters with the screw driver and make sure all wires are firm/intact....
Good luck.
My teakettle is about three months old. I was
Hi Nancy. There is a fuse or fuse like device in the bottom of your teakettle. There is also a temperature control switch which may be faulty. (if faulty, it is 'open' and the pot thinks the water is hot already) If you have a volt/ohm meter, you can probably find and replace it. You will need the replacement part and tools to install it, including pliers, screw driver and a crimp tool.
since it is three months old, you should consider contacting the manufacturer for relief on this matter.
Good luck on your repair and thanks for visiting FixYa.com today.
Paragon spin magic 5qr, when spinning causes bowl to shift.
Athletes often talk about the need to find "the zone." This is a state where everything seems to come together and they are able to achieve feats they never thought possible. For bowlers, this zone is often referred to as "the spin zone." When bowlers are able to get their bowling ball to rotate quickly on the lane, they can cause the ball to move in unexpected ways.
2/8/2024 2:23:46 PM •
Kitchen...
Answered
on Feb 08, 2024
