20 Most Recent Casio EXILIM ZOOM EX-Z600 Digital Camera Questions & Answers
I looked up the PDF for your camera, and it says: "use only an SD memory card or a Multimedia card with this camera. Proper operation is not guaranteed when any other type of card is used." I did not see a maximum size listed, but some cameras only accept 4GB, some 8GB. I think the important thing is "use only SD card".
Casio EXILIM... | Answered on Nov 05, 2017
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Casio EXILIM... | Answered on Jun 05, 2013
just go and purchase the new lanes for this model and replace the lanes and i am sure ur problem will sort out
Casio EXILIM... | Answered on Jan 31, 2013
Is the memory full ?
Casio EXILIM... | Answered on Jan 27, 2013
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Casio EXILIM... | Answered on Jan 24, 2013
Make sure you're using an SD card, 2GB or smaller. This camera will not work with higher-capacity SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
See the "Recording a Movie" section beginning on page 100 of this manual.
You don't need any special software in order to use your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Casio EXILIM... | Answered on Nov 19, 2012
remove batteries for 1 min and try again
Casio EXILIM... | Answered on Jul 04, 2012
get an sd card reader at walmart or any other place that has some computer stuff there like 5 to 10 dollars they plug in by usb connection and are usually much faster way to get stuff off the card.
Casio EXILIM... | Answered on May 20, 2011
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
90 questions posted
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
casio exilim 6 0 z600 megapixel camera
  • Cameras
