20 Most Recent Casio Exilim EX-Z500 Digital Camera Questions & Answers
Try downloading them to the computer first and then print them from there.
Casio Exilim... | Answered on Dec 18, 2017
You may download a copy of the manual from here.
Casio Exilim... | Answered on Jan 25, 2013
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
No. You have to use MMC or SD cards, 2GB or smaller.
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
You don't need any special software.
The EX-Z500 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with this camera.
Casio Exilim... | Answered on Feb 26, 2011
The problem is that your camera will only read SD cards, not SDHC cards, I checked its specification. You found your 256Mb card too small and bought a replacement, not noticing that it was SDHC. The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. I'm willing to bet that the 4Gb card you got is actually SDHC because 4Gb SD cards are so rare that I've even seen a guru on this site claim they don't exist. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it.
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
Casio Exilim... | Answered on Jan 21, 2011
you should try to use another usb cord! or try to turn on the camera when the cord is plugged in the pc
Casio Exilim... | Answered on Jan 03, 2011
Is it a SD card, or a SDHC (High Capacity) card of more than 8GB? Because the EX-Z500 natively does not support Large-SDHC.
Power off the camera. Press and keep pressed the MENU key, and while doing this, turn on the camera via the ON button. Press the MENU key until the firmware revision is displayed. I suspect you will see V1.01 or V1.00.
And Large-SDHC support is only present in release V1.02 of the Z500 firmware.
You should have the firmware updater-checker software; if not, you can find it on Casio website:
http://support.casio.com/download.php?rgn=4&cid=001&pid=170
This should fix it up. Let me know if it works.
Casio Exilim... | Answered on Jun 14, 2010
Did you format it in the camera before trying to use it?
Casio Exilim... | Answered on Mar 28, 2010
Check the ISO and exposure compensation.
Casio Exilim... | Answered on Mar 10, 2010
The little sliding in connection pieces could be broken or cracked or the memory stick could be genirec and is not compatible with your camera type.
Casio Exilim... | Answered on Aug 08, 2009
Did you try formatting the card through Camera menu options?
Regards,
Srinivas
Casio Exilim... | Answered on Apr 12, 2009
I was having the same problem... I put the camera in the cradle with it plugged into usb and then pushed play mode... the camera went to play mode and then i pushed and held the camera mode button while i was removing it from the cradle... it ended up turning on!!! i have no clue.. very weird
Casio Exilim... | Answered on Jan 31, 2009
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-z500 overexpourse
Casio Exilim... | Answered on Jan 19, 2009
sounds like u have a lens error. there has been some kind of damage to ur lens so you are going to have to send it in to be repaired.
Casio Exilim... | Answered on Jun 15, 2008
you can get a memory card reader at any walmart or wolf camera and you can tfer the pictures that way. your data connection or cable might be having a problem. you can pick up the card reader for around 15 off ebay maybe cheaper. hope this helps
Casio Exilim... | Answered on Apr 30, 2008
Casio Exilim EX-Z500 Digital Camera Logo
Popular Tags
31 questions posted
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
exilim ex
  • Cameras
