20 Most Recent
Toshiba E-Studio 2040c Copier Questions & Answers
Where does the document save when you scan it from the toshiba estudio 2040c
when you scan from e studio 2040c platen glass top it saves in the machine hard disk .It can be acessed by typing in the command line the ip address of the machine. with two backslash ip address backslash.for example the ip address of m aching is 192.168.2.10 then you have to type \\192.168/2.10\ .the folder named file share will be displayed on the pc and you can open by double-clicking it.....R Murali (
[email protected])
Disable printer sounds (beeping)
This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself. Just a guess. If you have an owners manual, I would check there to find how to reset it. You will want to enter the "menu" if there is one, and discover whether you can turn the beeping off. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section.
