20 Most Recent Sanyo VPC- C6 Digital Camera Questions & Answers
No, the camera can only support an SD card. An 8 GB card is an SDHC (SD High Capacity) card. However, the specs of the camera given in the manual list a 1 GB card as the highest density card known to work (but only one brand was tested).
The owner's manual for the Sanyo VPC-C6 is available at the Sanyo site. The direct link is http://us.sanyo.com/dynamic/product/Downloads/VPC-C6_OM_English-18468437.pdf .
I hope this helps.
Sanyo VPC- C6... | Answered on Apr 13, 2011
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Sanyo VPC- C6... | Answered on Aug 27, 2010
Sounds like your battery is really dead...won't take a charge. Try a new one.
Sanyo VPC- C6... | Answered on Apr 02, 2010
It should be detected by Windows as a video source once connected and powered up. Then you should be able to select it as a skype source as you normally would.
Sanyo VPC- C6... | Answered on Dec 01, 2009
Did you update the Firmware of the camera? The VPC-C6 can read and write to SDHC memory cards up to 4GB but it would require to have the latest Firmware being installed on the camera. Firmware can be downloaded via http://www.sanyo-dsc.com/english/support/updata/vpc_c6/index.html
Sanyo VPC- C6... | Answered on Mar 26, 2009
Try to use another 2 batteries. The problem could be with the batteries or the charger. By the way, did you checked batteries voltage or tried to use them in another appliance ?
Sanyo VPC- C6... | Answered on Jul 19, 2008
look for a small opening to insert a pin. many companies offer this hole as a way to reset the micro-controller. insert the pin during power up
Sanyo VPC- C6... | Answered on Mar 14, 2008
point driver installation manually to c:\windows\system32 manually pointing driver installation to system32 will helps u to reconize and also check for possible usb driver and usb port
Sanyo VPC- C6... | Answered on Sep 27, 2007
No worries, it is possible to recover deleted photos from camera. You may take a look at this guide
How to recover deleted photos from digital camera
the guide helped me before, easy to follow and helped me get back all my photos from my digital camera, hope that it helped you too!
Sanyo VPC... | Answered on Mar 13, 2017
From your description, it appears that the camera may have received an accidental blow, or else there is some foreign matter (sand or suchlike) in the lens mechanism. Either way, you are probably looking at professional repairs, which will be expensive, possibly prohibitively so. It may be more financially viable to replace your equipment.
If you can show accidental damage has occurred, then you may be able to claim on your household insurance.
Sanyo VPC... | Answered on Jun 19, 2016
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
  • Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives, Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
Sanyo VPC... | Answered on May 07, 2014
I had this same failure. It could be two things, one you bumped the lens an knocked it off the track it rides on. Easier done than you think, or the motor has failed on the lens. You can try to take it apart as I did, but you need time an small tools to do it. It took me three hours to take apart, an two hours to get back together. Dont throw it away I you can fix it. Someone could fix most likely if that is it
Sanyo VPC... | Answered on Mar 24, 2014
There is only one thing I can think of. If it is not this perhaps your camera is defect.
Your camera has a White balance setting. You can put it in Auto, Incand. Daylight, cloudy and Manual.
Check if it is in something other than Auto. If so, put it in Auto, till you think you can improve the colours by putting it in a special setting.
Sanyo VPC... | Answered on Jan 29, 2014
You can delete the photos by formatting the memory, go to the camera's Menu and scroll through the settings to Format memory.
Sanyo VPC... | Answered on Apr 07, 2013
Sanyo VPC- C6 Digital Camera Logo
10 questions posted
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
View Most Popular
VPC Sanyo
  • VPC Sanyo
Most Popular Question
sd card format
  • Cameras
