20 Most Recent
Kyocera FS-1320D Questions & Answers
How to set ip address for kyocera 1320d
Print a Status Page by pressing the green button for about 5 secs. Check the IP Address on the Status Page. If the IP Address is similar to your local network, you type that IP Address in an internet browser to open the Command Center (web interface).
If it is not similar, then you can change PC's IP to be similar to printer and via the command center, you change the printer's IP to a desired IP (similar to your local network) and restore then the IP of the PC to the one before.
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
