FixYa.com
Gateway FPD1975  19" LCD Monitor
All Products > Gateway > Monitors
Problems with Gateway FPD1975 19" LCD Monitor?
Troubleshooting and Support
Solved Problems for Gateway FPD1975  19" LCD Monitor RSS Feed Post a New Problem
monitor
monitor says it doesnt reconize my computer and has locked me out
1 Solution
a thin horizontal line across the screen
i turned my monitor (Gateway FPD1975 19" LCD) on the other day and there was a thin horizontal line across the...
1 Solution
Thin pale Horizontal line
I have a thin horizontal line that is present on the lcd screen. The screen is a VA903m model brought back 4-6 months...
1 Solution
LCD... Problem
i have problem, my lg lcd monitor display across a green line horizontally
2 Solutions
Black Line Across Screen
I have a Gateway 1440x900 LCD flatscreen, and recently a black line just popped out from no where. I've tried...
1 Solution
monitor
unit powers up ok,steady green light, when the computer is started monitor display blinks on and off (but no detail) as...
1 Solution
Display completely flipped to side
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Gateway FPD1975  19" LCD Monitor RSS Feed Post a New Problem
EzTune problem with lost PIN number to...
Ok, I go and download EzTune. But it will not work. I ask them for the PIN number. They tell me they have no record of...
Post a Solution
Blinking power up button
When I power up, the blue power button keeps blinking and at constant intervals the screen will blink white.
Post a Solution
locked out
i came home today and my monitor says it doesnt reconize my computer. And it has worked fine until now. About a month...
Post a Solution
fpd1975w 19" monitor(gateway)
I have an auto processing screen box constantly flashing in the middle of my screen. I also cannot work the menu box or...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size19"
Color Depth24-bit (16.7M colors)
Contrast Ratio700:1
Brightness300 cd/m??
Max. Resolution1280 x 1024
Dot Pitch.294 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time8 ms
Viewable Picture Size19 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalCE · UL · cUL · FCC Class B · NOM · VCCI · TUV-GS · Energy star
Digital Video Input StandardDVI-D
Max. Viewing Angle - Horizontal150
Max. Viewing Angle - Vertical135
Native (Recommended) Resolution1280 x 1024
Dimensions
Depth8.4 in.
Height16.6 in.
Width16.8 in.
Weight15.2 lb.
Warranty
Warranty3 Years
Gateway Contact Information
Main support number800-369-1409
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
