FixYa.com
Epson DM-M820   12.1" LCD Monitor
All Products > Epson > Monitors
Problems with Epson DM-M820 12.1" LCD Monitor?
Search inside Epson DM-M820 12.1" LCD Monitor Knowledgebase
Troubleshooting and Support
Solved Problems for Epson DM-M820   12.1" LCD Monitor RSS Feed Post a New Problem
I have heard about putting a monitor in...
I have heard about putting a monitor in "sleep mode" to save electricity. What is that, and how do I do it?
1 Solution
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
MONITOR REPAIR HELP
Hi I would like to appreciate for your help I have got an Acer monitor model G781 CRT Type its switching power...
1 Solution
Blank screen
Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute...
1 Solution
Need Data Sheet for M52327SP I.C.
Monitor is a 15 Inch MAG Inovisions. This chip is a Mitsubishi M52327SP Triple Video Amplifier I.C. I suspect. It is on...
1 Solution
Moniter wont respond
Here is the problem, I have this computer sorta put together (duct tape and all) It works fine, though I got a virus,...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size12.1"
Color Depth18-bit color
Contrast Ratio150:1
Brightness150 cd/m??
Max. Resolution800 x 600
Dot Pitch.307 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time30 ms
Viewable Picture Size12.1 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalCE · CSA
Input DeviceTouch Screen
Synchronization Range - Horizontal24 - 69 kHz
Max. Viewing Angle - Horizontal90
Max. Viewing Angle - Vertical40
Synchronization Range - Vertical50 - 85 Hz
Dimensions
Depth5.75 in.
Height12.72 in.
Width12.6 in.
Weight11.02 lb.
Warranty
Warranty1 Year
Epson Contact Information
Main support number1-800-922-8911
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
