20 Most Recent Sony MHC-EC50 Shelf System Questions & Answers
replace fuse.
Sony MHC-EC50... | Answered on Dec 07, 2017
You may have to disassemble your Sony system to get access to the CD drive in order to remove the jammed CD. You have to be careful to avoid destroying the drive in order to retrieve the CD.
Sony MHC-EC50... | Answered on Jan 10, 2015
It's minimal, don't worry about it. If the 1/2 watt of current it draws bothers you, unplug it from the wall.
Sony MHC-EC50... | Answered on Feb 11, 2010
Sounds like you have a short in the unit. You will have to take it apart and check the power supply for bad semis. My best guess is that your problem lies in the power supply. Let me know how this works out.
hardrocko
Sony MHC-EC50... | Answered on Jan 31, 2010
Mechanical loding problem send to service...
Sony MHC-EC50... | Answered on Dec 13, 2009
Does your turntable have two slots on the back where the dust cover fits? If so you could cut a piece of thin but strong plastic and Using epoxy glue them in place. That's how it fits on mine and then opens at an upward angle allowing you to place an album on.
Sony Audio... | Answered on Nov 13, 2018
The first thing I would check is your receiver/tuner and all connected components. Make sure all the settings are correct if it's not getting the correct signal they will not communicate to the subwoofer. The second thing I would check are the wires, even if they looked as if they're hooked up correctly they could be damaged in some way not receiving the signal to the other end check this with an ohmmeter and you can do this by putting it on the sound setting check one end of The Wire to the other and make sure it makes a beep or a humming noise, this means you have signal through the complete distance of the wire. If all that is correct then I would connect your subwoofer to another receiver/tuner. And if still no signal maybe the subwoofer is defective.
Sony Audio... | Answered on Nov 07, 2018
Should have a switch on the back of turntable. Switch to opposite setting.
Sony Audio... | Answered on Nov 04, 2018
speakers cuting in and out, not very loud anymore, or jsut not working. go to up dates an up date the drivers and or replace th speakers
Sony Audio... | Answered on Nov 03, 2018
Explain your full issue. What is the problem with sound?
Sony Audio... | Answered on Nov 02, 2018
Sony MHC-EC50 Shelf System Logo
15 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony mhc ec50 display screen light very
  • Audio Players & Recorders
