20 Most Recent
Compaq TFT8020 18.1" LCD Monitor Questions & Answers
I m using Intel D945GNT board, from last 2 weeks i
so this is a custom PC, yes, be nice to lead off with that fact first no?
so the driver for the ATI card is wrong
go to ATI and get the correct driver
dont expect W7 to magcially get any video driver right.
that is your job as custom builder.
(it can only be 2 things, it seems.
bad card
or its driver bad.
I assume you use BIOS to switch from the 2 , correctly)???
I have compaq tft8020, from last 2 days i m facing
mr farhanpk, When very strange stuff starts to appear on the screen of any older model ccfl -back-lit lcd display I would certainly suspect and investigate the monitors ac to dc internal power supply for BAD, SWOLLEN, LEAKY electrolytic filter capacitors. Check your pc with a "known-good" monitor to make certain it is not the pc causing the problem. 12fixlouie
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
