20 Most Recent
Acer AL1916S (Silver, Black) (Black, Silver) 19" LCD Monitor Questions & Answers
LG LM190E05 (SL)(01)
Gateway has multiple part numbers for the LCD inverter board. Part numbers V01216400103, V01216400104, and V01216400105
are for the Profile 5 and 5.5 series with a 15" monitor. Part number V01316500104 and maybe others are installed in Profile 5 and 5.5 with 17" and 19" monitors.
Also the LG part number for the 19" monitor provided in Gateway literature is LM190E02-A4. There is no mention of the LM190E05 SL in the product specs I have seen. Gateway does make special purpose runs and does change components without much much notice though.
The definitive source of exact information is Gateway Tech Support. It may cost you a couple of bucks to get answers, but the value added to your system with a 19" vs. 15" screen to say nothing of the viewing comfort should far outweigh the cost of accurate information.
Good luck with your upgrade. Please keep me posted on whatever you try be it successful or not. I too have a Profile 5.5 with 15" and have been considering the larger screen upgrade.
BillyB.
ViewSonic vg2230 back light keeps going off.
the inverter has gone out. You need to get a new one, but it might be cheaper to buy a new monitor than have it replaced.
If you are able to do it yourself look for it on ebay.
11/12/2017 9:58:16 PM •
Acer AL...
Answered
on Nov 12, 2017
No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
4/25/2014 1:41:55 AM •
Acer AL...
Answered
on Apr 25, 2014
