20 Most Recent
Maytag SAV5701A Top Load Washer Questions & Answers
Maytag A108 27 years old
It sound like Transmission Problems,Bury it and give it a Decent Burial, Dont Forget to Give Thanx.....ttech
Manual
I advice you check the link below to search for the manual
of your device, the link contain virtually almost all the manuals of
all device.
manualsonline.com
Type the above link to
search for the manuals of your device.
Take care.
MODEL # SAV5701AWW
There are hoses on the back of all washig machines that connect cold and hot water. If these hose were put on backwards you will not get hot water. Check the back of the mchine there will be a C=COLD AND H=HOT.
LET ME KNOW
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Water leaking
If the water is leaking at what seems like the beginning of the spin cycle it might be the hose connection to the drain pump or the pump itself. If so, it's a lot easier to fix than the drum seal.
WASHING mACHINE #82874100 110 SERIES
You need a good pair of grip pliers for the job. Release the grip, push further into pipe, fit pipe maximum into connection, grip clip again & clamp it over the rubber & connection. A proper grip plier is the key........
Washer won't work after the lid came off and was put back on
It sound like a lid switch issue.
The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch.
Look if it is not broken, moved from its place or has a lose wire.
If it's defective, it should be replaced.
Be aware you should plug out washer's power cable first !
Maytag A 108 suddenly will not spin or agitate or drain
It could be the timer, but it also could be the motor, or the transmission. Do you notice any signs of the motor trying to start? These would include a humming noise, lights dimming, etc. When you say there is no response from the machine, does this include the water valves & agitator, or just the spin?
Maytag top loading washer with UL code
Leveling: Ensure the washer is properly leveled. An unbalanced load can trigger the UL (unbalanced load) code. Use a level to check if the machine is sitting evenly on the floor.
Load Distribution: Make sure the clothes are evenly distributed in the drum. An imbalanced load can cause the UL code to appear.
Calibration: Some models have a calibration mode that can be accessed through the control panel. Running a calibration cycle might help the washer to detect load balance more accurately.
Electronics: There could be an issue with the control board or wiring harness. Inspect these components for any visible damage or loose connections.
Professional Service: If none of the above steps resolve the issue, it may be time to consult with a professional appliance repair technician who can diagnose and fix the problem more accurately. They may have specialized tools and knowledge to pinpoint the exact cause of the UL code.
Where is the counterweight in my Maytag washer model MVWC565FW2
If yours is a top loader it will mounted near the drum inside the machine. It will be a shaped block of concrete curved to sit close the actual drum. The most like places will be at the front, nearest you when your putting clothes in it, at about 3/4 of the way off the floor. It could also be in a similar place at the back of the machine.
Maytag LSE1000 Got the top off the machine but can't move top off because of all the attached wires. Is the only way to remove wires?
es, in order to remove the top of a Maytag LSE1000 washing machine, you'll need to first disconnect any attached wires. This is because the wires are connecting important components like the control panel and the sensors to the rest of the machine.
Here are the steps you can follow to safely disconnect the wires:
- Unplug the washing machine: Before you begin, make sure to unplug the machine from the power source to prevent any electrical shock.
- Locate the wires: Look for the wires that are connecting the top of the machine to the rest of the machine. They should be near the back of the machine where the top and bottom halves of the machine meet.
- Label the wires: Label the wires so you know which wire goes where when you're ready to put the machine back together. You can use masking tape and a marker to label each wire.
- Disconnect the wires: Gently pull the wires from their connectors, making sure to keep them separated so they don't get tangled. Be careful not to pull too hard, as this could damage the wires or the connectors.
- Repeat the process for all the wires: Repeat the process for each wire until they're all disconnected.
Once you've disconnected all the wires, you should be able to remove the top of the machine. Make sure to keep the wires organized and in a safe place while you're working on the machine. When you're ready to reassemble the machine, simply reconnect the wires in the reverse order you disconnected them.
