20 Most Recent
Bosch 24 in. SHV56C03UC Built-in Dishwasher Questions & Answers
Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Bosch dishwasher error code c1
HiPump-out not accomplished in normal time.Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
1/20/2024 2:53:57 AM •
Bosch...
Answered
on Jan 20, 2024
Bosch dishwasher leaking on the back
AI Bot Answer Deleted.
In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
8/27/2023 3:43:43 PM •
Bosch...
Answered
on Aug 27, 2023
I am not getting water into the dishwasher after changing the inlet valve
Check if there is anything in the large item trap or blocking the water level sensor. The dishwasher won't try to fill if it believes it is full. Try pressing and holding the Start button for 3+ seconds. The Clean LED should light up in a minute. If it does, try the on/off button and starting a new cycle. (This just clears any old programs from the memory.) Some washers will stop if they detected a water leak. Sometimes turning off the power for a while and checking for water in the cabinet below the dishwasher or in the motor area is useful.
The more likely items to check: Check the wiring between the inlet valve and the control board. Check the wires for corrosion at the connecting pins and for continuity. Broken conductors don't send a signal to open and close the valve. If those are okay, then the control board itself may be faulty.
Since this dishwasher is discontinued by the manufacturer, I don't know if all of the parts are still available. The only parts list for the SHE3ARL2UC/28 that I found is here:
https://www.partselect.com/Models/SHE3ARL2UC/ . They don't list any wires or the control board.
I hope this helps.
7/9/2023 9:13:29 PM •
Bosch...
Answered
on Jul 09, 2023
Bosch built in microwoven error E 3 how to fiend the problem
If you're seeing an E3 error on your Bosch built-in microwave, it usually indicates an issue with the touchpad or control board. Here are some steps you can take to try to fix the problem:
1. Unplug the microwave: The first step is to unplug the microwave from the electrical outlet for at least a minute. This will reset the control board and may clear the error code.
2. Check the touchpad: Sometimes, the E3 error can be caused by a stuck or malfunctioning touchpad. Check the touchpad for any damage or debris that may be interfering with its operation. Clean the touchpad with a soft, damp cloth and make sure it is completely dry before plugging the microwave back in.
3. Replace the touchpad: If the touchpad is damaged or not working properly, it may need to be replaced. Contact a Bosch authorized service center to order a replacement touchpad and have it installed by a qualified technician.
4. Replace the control board: If the touchpad is not the issue, the E3 error may be caused by a faulty control board. Again, contact a Bosch authorized service center to order a replacement control board and have it installed by a qualified technician.
In any case, if these solutions do not work, it's best to contact a qualified technician to diagnose and repair the issue, as microwave repairs can be dangerous due to the high voltage involved.
4/26/2023 4:42:30 AM •
Bosch...
Answered
on Apr 26, 2023
Spray arm hits plastic water supply as it spins, making a banging noise
I had this exact problem. There is a single hole on the underside of the arm, and it seems like the jet from it is enough to lift the arm so that it clears the plastic. The hole was clogged for me. Still have some thumping noise but it's 1/10th of what it was before.
4/17/2023 8:24:07 PM •
Bosch...
Answered
on Apr 17, 2023
Bosch SHU9915UC/11 dishwasher doesn't start wash cycle after replacing circulating pump?
If the dishwasher is not starting the wash cycle after replacing the circulating pump, it is possible that there is an issue with the control board. You may want to check the wiring connections between the control board and the new pump to make sure they are properly connected. If the connections are correct, you may need to test the control board and its various circuits to see if there is an issue with any of the components. It is also possible that there is a problem with a sensor or switch that is preventing the dishwasher from starting the wash cycle. You may need to consult the dishwasher's user manual or contact Bosch customer support for further assistance.
3/15/2023 8:30:34 PM •
Bosch...
Answered
on Mar 15, 2023
