20 Most Recent Bosch HBL 5036 Electric Single Oven Questions & Answers
2answers
After a lightning storm my
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
9/7/2017 3:26:38 PM • Bosch HBL 5036... • Answered on Sep 07, 2017
I have an error msg F03..what does that mean?
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
2/22/2010 8:50:55 PM • Bosch HBL 5036... • Answered on Feb 22, 2010
I no longer have my owner's instruction manual for
Go to Bosch.co.uk look up instruction manuals, type in your model and print
10/9/2009 8:38:05 PM • Bosch HBL 5036... • Answered on Oct 09, 2009
4answers
Hi I have a bosch
Exactly what is going on with the oven? Maybe I can be of some assistance.
3/6/2024 11:10:16 AM • Bosch Ovens • Answered on Mar 06, 2024
I have a integrated Bosch oven and it bleeps when I open the oven door and when it has been on for over 30 mins. What does the beep mean?
Generally it tells you that the food is cooked if the 'integrated oven has a microwave function. Or of course it is a fault. You can often fix that with a Power Reset. https://www.google.com/search?q=integrated+Bosch+oven+and+it+bleeps+when+I+open+the+oven+door+and+when+it+has+been+on+for+over+30+mins ..
4/9/2023 7:54:55 PM • Bosch Ovens • Answered on Apr 09, 2023
2answers
Bosch single wall ovens where is the thermal fuse located
Hi! The location of the thermal fuse in a Bosch single wall oven may vary depending on the model, but it is typically located on the back of the oven. To locate the thermal fuse, follow these steps:
  1. Turn off power to the oven: Before attempting any repairs, turn off the power to the oven by unplugging it or turning off the circuit breaker that supplies power to the oven.
  2. Remove the back panel: Locate the screws or bolts that hold the back panel of the oven in place and remove them using a screwdriver or socket wrench. Carefully remove the back panel to access the components inside the oven.
  3. Locate the thermal fuse: Look for a small, rectangular device with two wires attached to it. This is the thermal fuse. It may be located near the top or bottom of the back of the oven, depending on the model.
  4. Check the thermal fuse for continuity: Use a multimeter to check the continuity of the thermal fuse. Set the multimeter to the ohms setting and touch the probes to the two terminals of the thermal fuse. If the multimeter shows no continuity, the thermal fuse has blown and needs to be replaced.
  5. Replace the thermal fuse: If the thermal fuse has blown, replace it with a new one of the same rating. Install the new fuse in the same location as the old one and reattach the back panel of the oven.
  6. Test the oven: After replacing the thermal fuse and reassembling the oven, turn on power to the oven and test it to ensure that it is working properly.
If you are not comfortable working with electrical components or if you are unable to locate the thermal fuse in your Bosch single wall oven, it's recommended to seek the assistance of a qualified technician. Kind regards
3/25/2023 5:49:23 AM • Bosch Ovens • Answered on Mar 25, 2023
My Bosch oven display flickers often. Other times the clock is displayed as usual. What does this mean?
first thing I would do is check the cables that go to the clock, if they are OK then you likely have a faulty clock module which will need to be replaced.
2/23/2023 12:55:56 AM • Bosch Ovens • Answered on Feb 23, 2023
2answers
The knob on my electric Bosch oven doesn't grip onto the shaft and keeps turning/ twisting round. the actual knob is ok and pulls off to check, but the problem seems to be with the white plastic shaft
Get some epoxy putty, grease the shaft with Vaseline, put a small pea size piece of epoxy rolled thinly and insert it into the knob where the flat part registers on the knob. Push the knob into place and leave it 24 hours to cure. I use this.
Epoxy Putty - Amazon.ca
https://www.amazon.ca > Epoxy-Putty > k=Epoxy+Putty Results 1 - 48 of 696 - Epoxy Putty Stick, Yanyi Moldable Epoxy Glue for Crack Damage Fixing Filling or Sealing. Fast Permanent Repair for Metal, Glass, Wood, ... ..
2/9/2023 6:51:00 AM • Bosch Ovens • Answered on Feb 09, 2023
Replacing Thermostat in Bosch HBL455AUC
Yes, the tube is fed in from behind or above. Some thermostat bodies have a small adjusting screw to allow you to calibrate if it is fairly close. The videos show it is a simple job.
1/23/2023 12:11:58 AM • Bosch Ovens • Answered on Jan 23, 2023
Bosch convection microwave HMC87151UC does not heat in convection mode.
The issue you're experiencing with your Bosch convection microwave not heating in convection mode could be caused by a few different things. Here are a few things to check:
  1. Check the settings: Make sure that the microwave is set to convection mode and that the temperature and time settings are correct.
  2. Check the element: The bottom heating element is responsible for providing heat during convection mode. Make sure that the element is not damaged or burnt out. You can visually inspect it, if it is damaged it will need to be replaced.
  3. Check the fan: The fan is responsible for circulating hot air during convection mode. Make sure that the fan is not blocked or damaged. If it is, it will need to be replaced.
  4. Check the control board: The control board is responsible for controlling the functions of the microwave. A malfunctioning control board could prevent the microwave from heating in convection mode.
  5. Check for a blown thermal fuse: A thermal fuse is a safety device that cuts off power to the oven if it overheats. If the thermal fuse is blown, it will need to be replaced.
  6. Check for a blown thermal cut-off: A thermal cut-off is a device that cuts off power to the oven if it overheats. If the thermal cut-off is blown, it will need to be replaced.
1/14/2023 11:05:03 PM • Bosch Ovens • Answered on Jan 14, 2023
Calibrating Bosch HBL 455 A UC Dual Oven
You may need to replace the thermocouple inside of the oven.
1/9/2023 5:59:45 PM • Bosch Ovens • Answered on Jan 09, 2023
Bosch wae24166gb/06 washing machine location heating element
The heating element is located on the back of the Bosch WAE24166GB/06 washing machine.
12/14/2022 10:45:12 AM • Bosch Ovens • Answered on Dec 14, 2022
When i turned on the
you need to replace the control board (clock) this should take cvare of your problem
11/14/2022 7:54:58 PM • Bosch Ovens • Answered on Nov 14, 2022
I have a Bosch hbn43m551b double oven and forgot the which wires go where...
There is some basic help here. Some companies put a wiring diagram on the inside of the back panel. https://www.google.com/search?q=bosch+hbn43m551b+wiring+diagram ..
11/1/2022 12:02:45 AM • Bosch Ovens • Answered on Nov 01, 2022
The Bosch oven does not turn off after the clock runs out
It is the automatic oven timer and not the kitchen counter timer ...?
7/2/2022 12:02:38 PM • Bosch Ovens • Answered on Jul 02, 2022
How do open a locked hinge on my built in Bosch oven
First of all, oven doors are not designed to be disassembled for cleaning of the sealed glass panel. That being said, you may be able to use a coat hanger to pry the hinges open against heavy spring pressure to allow reassembly.
3/30/2022 1:38:11 PM • Bosch Ovens • Answered on Mar 30, 2022
I need the heating element for Bosch Oven Model HEI7152C/05
google heating element for Bosch Oven Model HEI7152C
1/3/2022 1:16:42 AM • Bosch Ovens • Answered on Jan 03, 2022
Replacement oven for HBN131250B
then go shopping , we can not do it for you
11/5/2021 2:34:27 PM • Bosch Ovens • Answered on Nov 05, 2021
Bosch HBL 5036 Electric Single Oven Logo
Popular Tags
4 questions posted
Top Bosch Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
View Most Popular
Bosch Ovens
  • Bosch Ovens
Most Popular Question
no longer owners instruction manual
  • Ovens
