When I try to turn the television on, the green light simply flashes on and off for about a minute....
(More)
When I try to turn the television on, the green light simply flashes on and off for about a minute. Then the red light flashes on and off for about 30 seconds before the television shuts off.
Problem started with bright sky images. There would be large spots with a hazy halo where colors try...
(More)
Problem started with bright sky images. There would be large spots with a hazy halo where colors try to blend. Now has progreseed to any bright images. Mainly light colors.
I have replaced the lamp and the color wheel as was diagnosed by a local tv repair shop. neither...
(More)
I have replaced the lamp and the color wheel as was diagnosed by a local tv repair shop. neither fixed the problem.
i have panasonic pt60lcx64 tv,and there is blue color ehwn i watch tv,is there any way to fix this...
(More)
i have panasonic pt60lcx64 tv,and there is blue color ehwn i watch tv,is there any way to fix this thanks
i had the lamp replaced and now when i turn my tv on it says. replace lamp soon or reset the hour...
(More)
i had the lamp replaced and now when i turn my tv on it says. replace lamp soon or reset the hour meter. is there a reset button if so where
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
