It is stuck on channel 5 - If I go to any other channel it says "channel not available". ...
(More)
It is stuck on channel 5 - If I go to any other channel it says "channel not available". I need to get it to channel three so that my Rogers HD box will work
Panasonic DLP PT-56DLX75--Authorized service tech replaced entire assembly in back. Said lamp was...
(More)
Panasonic DLP PT-56DLX75--Authorized service tech replaced entire assembly in back. Said lamp was still ok. Now even after this service, power indicator lamp flashes orange 6 times after TV on for about an hour. When picture is on, shadows of faces and dark walls look pixelated. Picture not as good as before problems surfaced. Thanks for your help I have the same issue on a Panasonic PT-56DLX75. Works great for about an hour then shuts off and displays a yellow/orange flashing light at the power button. I can unplug it and get it to come back on, but a few minutes later the problem returns. I've tried cleaning it out and making sure it wasn't a heat issue but with no change.
(More)
My son was watchind tv and it went to a double picture showing in a curved format anyone know what...
(More)
My son was watchind tv and it went to a double picture showing in a curved format anyone know what part i might need.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
