not picking up all the digital channels, i have the latest firmware. tuner card has been replaced,...
(More)
NOT PICKING UP ALL THE DIGITAL CHANNELS, I HAVE THE LATEST FIRMWARE. Tuner card has been replaced, no cable box and a visio picks up the channels fine.
In 1080 mode the picture is cut off in a frame around the edge so that the tops of heads and...
(More)
In 1080 mode the picture is cut off in a frame around the edge so that the tops of heads and subtitles are cutoff. This is do to the aspect being 16:9 which per the manual is the only way to view 1080p. Is there anyway to fix this? Or do I just need to go back to 480 or 720?
I have a TH-42PX500U and I cannot get rid of the small picture-in-picture frame that is appearing. i...
(More)
I have a TH-42PX500U and I cannot get rid of the small picture-in-picture frame that is appearing. i do not even know how it got there it he first place. Any help?
I have a Panasonic Plasma TV, I get 3 of 4 stations as digital now, why can't I get the 4th channel,...
(More)
I have a Panasonic Plasma TV, I get 3 of 4 stations as digital now, why can't I get the 4th channel, from the same area
I forgot my unlock code so I can't autoprogram the plasma tv. How do I reset this code> I...
(More)
I forgot my unlock code so I can't autoprogram the plasma tv. How do I reset this code> I want to pick up more channels with my built in tuner. I had a cable card and now it asks for a code which is 4 digits I can't program the tv without. Thanks Jay
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12 digital changeover) can cause the sound to be missing on those...
written by jmorganti
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
