picture is only coming up on half of the screen on my panasonic plasma tv. The other side of the...
(More)
picture is only coming up on half of the screen on my panasonic plasma tv. The other side of the screen is black.
Tv worked an hour ago now all of a sudden it has a 2inch wide by 12 inches long running verticall...
(More)
Tv worked an hour ago now all of a sudden it has a 2inch wide by 12 inches long running verticall from the middle of the top to halfway down
I can not turn on the TV ,when I try to turn on the power the led beside the power button, blink 12...
(More)
I can not turn on the TV ,when I try to turn on the power the led beside the power button, blink 12 times and wait for while repeat it.
not enough to make the picture unwatchable but annoying enough to make it unpleasant. TV is around 6...
(More)
not enough to make the picture unwatchable but annoying enough to make it unpleasant. TV is around 6 years old and problem just started last month.
My plasma will not turn on. The power button will not even work. The only activity is the red power...
(More)
My plasma will not turn on. The power button will not even work. The only activity is the red power button on the tv blinking 10 times, then stopping, then repeating. I unhooked the power cord a few days ago, and could never get the tv to work since then.
The TV is completely blank and won't turn on anymore. The power light blinks 7 times in succession....
(More)
The TV is completely blank and won't turn on anymore. The power light blinks 7 times in succession. Anyone know the blink code meanings?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12 digital changeover) can cause the sound to be missing on those...
written by jmorganti
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
