20 Most Recent Panasonic CQ-C5301U CD Player Questions & Answers
It was working fine just
Check your fuses and make sure one didn't blow. Also, re-check power at the back of the unit to make sure you have 12V on the battery/memory wire(yellow) and the switch power wire(red). The battery wire is always hot and the red should have power once you turn on the key.
6/26/2011 7:05:14 AM • Panasonic... • Answered on Jun 26, 2011
I set the time on
You may find this link to manual download will work just fine.
https://panasonic.ca/PDP/OperatingInstructions/cqc5301-5401-oi-eng.pdf
2/18/2011 11:43:30 AM • Panasonic... • Answered on Feb 18, 2011
0answers
Color code for panasonic model cq5301u [wiring
okay here it is
on all aftermarket radio they follow a color code
iginition 12 volts red
constant 12 volts yellow
ground black
remote wire amp turn on blue/white stripe
speakers
Lfront + white
Lfront - white/black stripe
Rfront +gray
Rfront _gray/black stripe
Lrear +green
Lrear -green/black stripe
Rrear + purple
Rrear - purple/black stripe
some radio have other wires too
like dimmer wire orange
power anntenna blue
and some flip screen radio have parking brake wire green
since your needing a wiring diagrame i would take it to a mecp professional 12 volt installer to install radio . about as fast as you blink your eyes you can fry the electrical system in your car and cost you 100's or 1000's of dollars buy and rewiring you car to fix it .
[email protected]
for more questions
10/16/2010 4:06:28 PM • Panasonic... • Answered on Oct 16, 2010
I boosted my car wrong, and now my audio doesn't work
? confused on what you mean?
7/1/2009 11:33:48 PM • Panasonic... • Answered on Jul 01, 2009
Rear wiring connection/wiring
red= (switched)power+ black is ground = connect to metal surface yellow is memory needs battery+ at all times white/whiteblack is front left speaker grey/greyblack is right front speaker green/green black is left rear speaker violet/violetblack is rear right speaker
5/29/2009 12:45:00 AM • Panasonic... • Answered on May 29, 2009
Wiring problems
the easy thing to do is to go to Best Buy or to www.crutchfield.com and buy the wiring harness for your car and for your radio if you still do not have it along the the dash kit which will include the instructions for you car. Crutchfield is really the way to go to buy the parts you can just call them and they will get you what you need they may even get you a manual. If they do not get you a manual you can always go to panasonics website and download current and old product manuals in PDF formats which can be viewed with free software like adobe PDF viewer or Foxit.
4/23/2009 3:15:52 AM • Panasonic... • Answered on Apr 23, 2009
Rear speakers low volume
Double check your settings on your radio. Mostly your Fade levels. If that is not the cause you may a chip going out in the head unit. The chip is fairly simple to purchase, remove and replace depending on your soldering skills. Let me know if the fade levels correct it. If it doesn't then I will help you find the replacement chip to order and replace.
3/18/2009 1:45:57 PM • Panasonic... • Answered on Mar 18, 2009
Panasonic CQ-C5303W
im not to familleaer with the unit, but i know the disc has to be burned as data for Kenwoods to pick up.
Hope this helps,
Don
1/3/2008 11:39:19 PM • Panasonic... • Answered on Jan 03, 2008
Wont work
is there a factory amp in the car that you need to hook up the remote turnon lead to, if so its usuallt the power antenna wire
Don
1/3/2008 11:38:02 PM • Panasonic... • Answered on Jan 03, 2008
CQ C5301U
can you check and see if plugged in or if power is getting to cd changer first, if so then check for jammed cds, in no jammed cd then reset system. should see some kind of reset on changer or radio and start over
8/16/2007 4:18:49 PM • Panasonic... • Answered on Aug 16, 2007
Battery dead, boost car, cd player doesnt work anymore...
Get a testlight or DMM and test all of the power wires. It's your only hope.
11/5/2006 7:39:58 PM • Panasonic... • Answered on Nov 05, 2006
My rca preouts doesn't work on my panasonic cq-df802u stereo
The rca plugs can short out. Or one of the comparator that is for audio selection. Might can get away with just replacing them
12/21/2023 3:14:21 AM • Panasonic Car... • Answered on Dec 21, 2023
Panasonic CQ-FN46E0GX No Sound
Hi Greg, I'd say you have a bad audio output IC, generally this will take out the fusable resistor that feeds the output stage, you should be able to find a part number on the IC, do a pin out and check between B+ and ground pins with it in circuit and see if you see a short. I don't know if you can find a service manual for it but hopefully you wouldn't need one
5/31/2023 10:09:12 PM • Panasonic Car... • Answered on May 31, 2023
Panasonic CQ-C5301U CD Player Logo
24 questions posted
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Car Audio & Video
Most Popular Question
color code panasonic model cq5301u
  • Car Audio & Video
