20 Most Recent Maytag MAT12CS Top Load Washer Questions & Answers
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Maytag MAT12CS... | Answered on Nov 11, 2017
you need a locksmith.  Because of the key design
Maytag MAT12CS... | Answered on May 17, 2013
open service door,move switch and display will read 6-- (6 and the # of coins set for) use the buttons top and bottom to go up or down to desired amount
Maytag MAT12CS... | Answered on Mar 01, 2013
Possible there is level fault in the floor setting. You can use a simple spirit level and adjust the level of the washer with a tilt to the rear for easy drain. Also check for bearing fault if there is wobbling, check for counter weight or alignment fault of the drum if the frames are rusted.
Maytag MAT12CS... | Answered on Aug 24, 2012
check the drain hose to see if it is crimped, or loose belt on pump, or something in pump or inbetween the tubs.or obstruction in hose going to drain pump.
Maytag MAT12CS... | Answered on Aug 08, 2011
If it is belt drive the belt could be broken or the gearbox is faulty. That is provided the water level is reached and the water shuts off when the correct level is reached. If no belt the gearbox coulping is stripped. Does it spin?? if it does then the gearbox coupling is ok. Hope this helps.. Tony http://www.appliances.cjb.net
Maytag MAT12CS... | Answered on Jan 22, 2011
hi the first thing i would check is the pump if it not the pump may be tub baring witch some special tools to replace jim
Maytag MAT12CS... | Answered on Oct 20, 2010
Maytag MAT12CS Top Load Washer Logo
48 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag la23cs as spin cycle
  • Washing Machines
