20 Most Recent Ricoh Lanier LD122 Toner 66000 Yield Type 2212 - Genuine OEM toner Questions & Answers
By-pass bottom plate error.
1. Check or replace the harness.
2. Replace the by-pass motor.
3. Replace the by-pass tray HP sensor.
Ricoh Office... | Answered 6 hours ago
Hi found this on you're problem
possible MAIN MOTOR LOCK....
CAUSES
TO MUCH LOAD ON THE DRIVE MECHANISM
:::::: MAIN MOTOR DEFECTIVE.,.
CALL. 13RICOH
Ricoh Office... | Answered on May 22, 2019
Place a telephone call to your local Ricoh service rep and specify code sc556.
Ricoh Office... | Answered on May 20, 2019
u need to replace PS unit or BC unit, one of them is defective
Ricoh Office... | Answered on May 15, 2019
that is software error .u cannot select application function it is software bug or a RAM or DIMM option necessary for the application is not installed or not installed correctly
By using your telephone to contact your local Ricoh servicer and reporting error sc 20252
Ricoh Office... | Answered on May 12, 2019
Sc 816 Energy saver sub system is not operating correctly because the controller board isdefective
Ricoh Office... | Answered on May 08, 2019
SC878 means incorrect updating for the system firmware or defective flash ROM on the controller board manual says : Replace the controller board.
sc508 is By-pass bottom plate error that means the signal from the by-pass tray HP sensor does not change for 1.0 second after
the by-pass motor has rotated counterclockwise.
the reason could be :
• Disconnect or defective harness of the by-pass motor
Ricoh Lanier LD122 Toner 66000 Yield Type 2212 - Genuine OEM toner Logo
1 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
huge problem figure out cancel incoming
  • Office Equipment & Supplies
