20 Most Recent
Canon ImageRunner C-2620 Copier Questions & Answers
E000020-0460
Toner Code,Replace the toner cartage,
12/13/2011 1:19:35 PM •
Canon...
Answered
on Dec 13, 2011
What does e520 error means
the error is related to the finisher. if ur copier is being used in dusty conditions then blow all the dust from the finisher as some sensor is getting blocked thats why error .use a fast air blower
8/18/2011 12:44:04 PM •
Canon...
Answered
on Aug 18, 2011
I have been given a
First make sure your usb cable is working fine try it in different usb ports of computer.
Make sure driver installed correctly.
If you use wireless network then make sure wireless is enabled in router and DHCP enabled in router.
Make sure wireless network driver working fine on computer and your printer ip address s in the range of local network.
Let me know if you need further assistance.
Thanks for using FixYa.
11/5/2010 2:21:56 PM •
Canon...
Answered
on Nov 05, 2010
I have 2620 canon copier
Enter service mode & clear all & restart.
Additional function > 28 > Additional function
Go to clear & select all.
8/15/2010 1:35:59 AM •
Canon...
Answered
on Aug 15, 2010
Can I clean drums
Unfortunately they need to be replaced when they start to fail, the cleaning roller or blades are usually worn, or the drum itsef is worn out therefore needs to be replaced sorry.
4/7/2010 10:40:47 PM •
Canon...
Answered
on Apr 07, 2010
Change rooler on fuser
The process in general is lengthy.. If you can get to the spot where the pinch rollers are, and if the symtoms are paper not pulling through.. I watched my Service Group, that I use to hire, use regular rubbing alcohol on the rubber wheels, as they get dry and slick ? ..and this renews the grip again. This also will clean your main fuser roller when you use the wrong paper in it .
8/8/2009 9:21:01 PM •
Canon...
Answered
on Aug 08, 2009
