20 Most Recent Nikon Coolpix L110 12.1 Megapixel, 15x Optical Wide Angle - Telephoto VR Super Zoom, 3.0 Inch LCD Screen, HD Video Digital Camera - Matte Black - Factory Refurbished Questions & Answers
You may download the current versions of all (free) Nikon software from here.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Nikon Coolpix... | Answered on Oct 02, 2012
Since you have neglected to tell us the make and model of the tripod, this can only be a generalisation - broken down into easy steps for you.
1) unclip the Q/R plate from the tripod head.
2) screw the Q/R plate to the base of the camera, using the tripod threaded socket.
3)re-attach the Q/R plate to the tripod head.
BTW, when using the camera on a tripod, use a remote control to prevent camera movement.
Nikon Cameras | Answered 8 hours ago
Try this YouTube video for timer settings:
https://youtu.be/Vzu0PVD7SPM
Nikon Cameras | Answered on Jul 07, 2019
This means there is a problem of some description with the equipment, and it requires either service or repair.
Nikon Cameras | Answered on Jul 04, 2019
Hello Amian,
Here is a link to the manual of your camera that may be helpful to you.
Good luck,
JP
https://www.manualslib.com/manual/745954/Nikon-D90.html
The best solution would probably be to check with your seller if it's still under warranty and let him solve the problem, but in case you want to be sure, go through the manual of your camera to see what the lights mean, if you don't have a manual you can find it here:
Nikon Coolpix B500 PDF manual download
Nikon Cameras | Answered on Jun 28, 2019
Mine did to i wait then it was fine! wow
Nikon Cameras | Answered on Jun 27, 2019
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Nikon Cameras | Answered on Jun 18, 2019
When you are using different modern Nikon lenses, this is strange.
can you tell what lens(es) you get the message with?
brand and model please. And if one of these lenses worked before? And if you did an firmware update recently.
No. Bluetooth is different than WiFi just as NFC(near field communication) is different from the first two. All radio spectrum but different frequencies.
Unlikely, but possibly two dodgy batteries ? Are they gen Nikon or replacements ? Other cause might be electronics issue with camera, or bad connection between lens and body - have you tried cleaning the contacts ?
Nikon Cameras | Answered on Jun 16, 2019
those lenses are usually manufactured for specific model cameras if it works fine on your it's because that's the type of camera it was manufactured for. if it doesn't work on hers in AF then it's because the pin out on the lense isn't the same for her camera as it is for yours.
Nikon Cameras | Answered on Jun 15, 2019
Special tools, special skills and experience - that is why camera technicians are so expensive. You need to take the lens to a specialist.
Nikon Cameras | Answered on Jun 10, 2019
Interesting - looks as if there could be a problem. Have you inadvertently set 'Write Protect' on the card, perchance ?
Nikon Cameras | Answered on Jun 06, 2019
Nikon Coolpix L110 12.1 Megapixel, 15x Optical Wide Angle - Telephoto VR Super Zoom, 3.0 Inch LCD Screen, HD Video Digital Camera - Matte Black - Factory Refurbished Logo
1 questions posted
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
Nikon Cameras
  • Nikon Cameras
Most Popular Question
lost cd l110 down load computer
  • Cameras
