20 Most Recent
Maytag MDG21PD Electric Commercial Dryer Questions & Answers
Maytag old dryer flame will not ignite when glow thing lights up
The 'glow thing' is called a Thermocouple and is a safety device that makes sure that there is a flame before the main gas valve to the burners opens up.
Because it is a gas appliance and the very REAL danger of explosion, all gas appliance must be worked on by a gas certified technician. It is not a big job and they normally carry thermocouples in the van.
Where is the pilot light on a Maytag dryer
what is the model number? free standing pilots have been gone for several years. Google your model number and include parts.
This will give you sites that sell parts.
You most likely have and hot surface ignitor.
What is the electrical capacity of Maytag MDG9700BWW?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=the+electrical+capacity+of+Maytag+MDG9700BWW%3F
Then check related searches
MOTOR: 1/4HP,120 volt,60 Hz,single-phase,thermally protected against overload,auto-reset. EXHAUST:Use a minimum of 4"(10.2 cm) diameter rigid aluminum or galvanized steel duct. Never use plastic,nonmetal or combustible duct. HEAT SOURCE/ELECTRICAL REQUIREMENTS: Electric model- 5,300 watt nichrome helix coil; 240 volt,AC,60 Hz; 30 amp fuse. Gas model-Single port burner with automatic electric ignition; 22,000 BTU/hr. 15 amp fuse. Self-adjusting valve automatically compensates for variation in gas pressure. WEIGHTS (Crated/Uncrated):
What dose it mean F07 Maytag dryer
The F70 indicates a communication error code between the main control on the top left and the user interface on the front. Unplug the machine and remove the top. Check the connection on the board in the white plastic housing on the top left. Next check the connections on the board on the front.
Maytag Stove Model MER5730AAA ... Baking element stays on. (Relay Board?)
If the baking element stays on even when the oven is turned off or when it's set to a different temperature, the issue might be with the relay board. The relay board is responsible for sending power to the bake element when it's supposed to be on, and cutting off power when it's supposed to be off.
To confirm if the relay board is the culprit, you can try the following:
- Turn off the power to the oven at the circuit breaker.
- Remove the back panel of the oven to access the relay board.
- Look for any signs of damage or burning on the board.
- Inspect the connections and wiring for any signs of damage or burning.
- Use a multimeter to test for continuity across the contacts of the relay board that control the bake element.
- If the continuity is present when the oven is turned off, or if the board is visibly damaged or burnt, then it's likely that the relay board needs to be replaced.
If the relay board is determined to be the issue, it's recommended to have a qualified technician replace it as working with electrical components can be dangerous.
MAYTAG NEPTUNE DC MOD# MCE8000AYW interior lights are not coming on.
If replacing the bulbs did not fix the issue, then it could be a connection issue or a faulty light switch. You can try checking the connections to the light switch and the light assembly to make sure they are secure and properly connected. You can also use a multimeter to test the switch and see if it is functioning properly. If the switch is faulty, it will need to be replaced. If you are not comfortable doing this yourself, it is best to consult a professional technician.
Maytag MDE4658AYW electric running hot on all settings, even on air fluff
If your Maytag MDE4658AYW electric dryer is running hot on all settings, even on air fluff, it is likely that the heating element is not working properly. Make sure that the heating element is securely connected to the dryer and that the power switch is in the "on" position. If the problem persists, you may need to replace the heating element or contact the manufacturer for assistance.
