The top panel and the control panel need to be removed first before the front panel can be removed. Once the top panel is off, the screws attaching the control panel to the dryer cabinet are exposed. The screws securing the front panel to the dryer cabinet are exposed once the control panel is removed.
Disconnect power and remove the two screws attaching the top panel to the rear of the dryer.
Slide the top panel towards the rear to clear the screw head from the flange at the bottom side of the top panel then lift it from the unit.
Remove the screws securing the Heater PCB Assembly at the left side of
the dryer cabinet then flip the assembly over and disconnect the black
and the white connectors from the board.
Remove the four screws attaching the control panel to the dryer cabinet then rotate it down and remove it from the dryer.
Remove the two screws in the door area and the four screws from the top of the front panel and attaching it to the dryer cabinet.
Pull the front panel forward then disconnect the interior light harness.
Lift the front panel off the tabs across the bottom and remove it from the dryer.
Reassemble the dryer in reverse order of the disassembly steps.
