20 Most Recent
IBM Infoprint 1512 Laser Printer Questions & Answers
How reset photoconductor ibm infoprint
The instructions for IBM Infoprint 1412/1512 printer's photoconductor is the same as the Lexmark E342.The instructions are located here:
http://support.lexmark.com/index?page=content&id=HO2564&locale=en&userlocale=EN_US Recap of Instructions:To Reset Photoconductor page count:1. Turn off printer2. Press and hold the Select and Return buttons at the same time on the panel and turn the printer on (continue holding down buttons until printer screen displays "Performing Self Test" or "CONFIG MENU").3. If "Reset PC Cnt" does not appear on screen, press the left or right menu button until it appears.4. Press "Select" and the message "Resettting PC Cnt Value" should briefly appear indicating the page count is reset.5. Turn off printer when "CONFIG MENU" appears again.6. Wait 5 or more seconds and turn back on. Done.7. It is suggested to check and verify that the PC Count is reset by printing a menu setting page:a. Press left or right menu buttons until you see "Utilities Menu" and press "Select".b. Press left or right menu button until you see "Print Menus" and press "Select".c. This should print out the information. Look for "Cartridge Info" and the word "Photoconductor". It should indicate "OK" or close to 100%.d. If not showing "OK", print 10-20 pages and Print Menu again to check. If still not, reset PC again and check again.
I want to set up
I used an Lexmark E342 printer driver. It is the Lexmark version of the printer and the driver that is readily available for Windows 7.
I have a IBM Infoprint
Those photoconductors have a limited life and have to be replaced. The message is warning that it is near the end of its life and wants you to have one ready when it goes out. Most printers will prevent you from printing when it reaches the end of the service life, some will let you continue to print but you will get reduced image quality. Either way, you'll need a new one soon.
No installation disc
your drivers are available here:
http://www-01.ibm.com/support/search.wss?rs=95&apar=exclude&tc=SRDUKD&q=psd1*&dc=D400&dtm
scroll down to number 5 if you have windows XP, number 2 for vista. this link will take you to the operating sytem specific page for your driver, scroll down again and choose one of the first two FTP buttons marked english, there are both the postscript drivers and the PCL drivers.
Installation Instructions
- Download the file to a temporary directory or any desired folder.
- Go to the folder where the .EXE package resides.
- Double click on the .EXE file to run the installation program.
- Follow the instructions in the pop up windows to install the drivers for your printer.
