FixYa.com
IBM E54  15" CRT Monitor
All Products > IBM > Monitors
Problems with IBM E54 15" CRT Monitor?
Search inside IBM E54 15" CRT Monitor Knowledgebase
Troubleshooting and Support
Solved Problems for IBM E54  15" CRT Monitor RSS Feed Post a New Problem
monitor broblem
it is ibm crt monitor that the picture is blinking
1 Solution
monitor ibm e54 coloure bluish background
coloure problem of ibm monitor e54
1 Solution
TNT2 m64 and monitor (maybe) problems.
Hi, I have a TNT 2 m64 32mg pci card 400 celeron 128 megs pc100 ram and an IBM E54 monitor. I have a two...
5 Solutions
PRINCETON LCD-15BLK MONITOR
Monitor is less than 2 year old. Just went blank. When you turn the power on, the power light comes on and the LCD...
2 Solutions
monitor
i want 19" monitor but my address is india what your support
1 Solution
monitor out of range
when playing a game the screen goes black and a massage says out of range: H: 255 KHz, V:239.9 Hz.
4 Solutions
some letters on monitor are fading out
I have a larger Dell monitor and an Nvidia5200 video card. Some letters show up as not filled in completely.
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for IBM E54  15" CRT Monitor RSS Feed Post a New Problem
monitor
my monitor has no display when i turn on my system unit, but when i press the adjustment menu from monitor it has...
Post a Solution
Monitor settings; how do I change the...
I press the menu button on my monitor, and the brightness is at 100%, but photos/videos are still quite dark. I don't...
Post a Solution
test
how to use softjig
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio4:3
Size15"
Max. Resolution1280 x 1024
Dot Pitch.28 mm
Monitor TypeCRT
Viewable Picture Size13.8 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalUL · FCC Class B · Nemko · DHHS · Energy star · MPR-II
Synchronization Range - Horizontal30 - 69 kHz
Native (Recommended) Resolution800 x 600
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 720 x 400
Synchronization Range - Vertical50 - 120 Hz
Dimensions
Depth15.4 in.
Height15.2 in.
Width14.6 in.
Weight26.4 lb.
Warranty
Warranty3 Years
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
