20 Most Recent
Sharp Vl-e39 Vl-e39u 8mm Video8 Camcorder Player Video Camera Video Transfer Questions & Answers
Where can I find the PC Connect cable for a Sharp Camcorder Model VL-SD2OU
You may be able to find the PC Connect cable for your Sharp Camcorder Model VL-SD2OU at an electronics store or online retailer that specializes in video and camera equipment. You can also try contacting Sharp directly to see if they have the cable in stock or if they can suggest a retailer that carries it. Alternatively, you may be able to use a generic USB cable to connect your camcorder to your computer, depending on the capabilities of your camcorder and computer.
Keep in mind that you may need to install any necessary software or drivers on your computer before you will be able to access the video files on your camcorder
How can I find a US repair shop to have my Sharp Hi-8 camcorder repaired? A
Newton Ellis & Co. repair most makes and models of camcorders and video cameras. If you are having a problem with your camcorder or video camera then bring or send it in for a free estimate, we can usually give you an idea of what is wrong with it and an idea of the cost. If you can't get in to our shop then give us a call and we will try to help you over the phone or just send an email, see the 'Contact Us' page. We do try to make the repairs as cost effective as possible so if you have an older model then we will try our best to keep the cost down if at all possible.
E commerce Software ecommerce software solution & Online Shopping Cart for small business
https://www.tritansolutions.com/Home/Ecommerce-Solutions
I WANTS SHARP MIN DV VL-DC5 DRIVER
Hi there
Okay so I have carried out some research on the problem you are having.
The VL-DC5 does not have drivers online to download because the drivers in windows XP support this model camcorder
The problem is that you are probably trying to connect the device to your computer using USB.
The drivers in windows XP are only compatible with this camcorder when using Firewire cables.
If you don't have a firewire cable then you will need to buy one and use this to connect your camcorder to your pc.
It should work fine after you have tried this.
Let me know how you get on!
