20 Most Recent Kensington StudioMouse Wireless Questions & Answers
I still have the manual for my mouse.  Model number 64321.
When this mouse was manufactured it used NiCad batteries which developed a memory much more than the newer batteries.  The older NiCad batteries needed to be conditioned occasionally so Kensington provided a way to do that with the charging base.
The red light is for indicating discharge status of NiCad batteries.
The red light will flash quickly when you press the battery discharge button on the bottom of the base.  This indicates that you now have 5 seconds to place the mouse in the charging base for battery discharge.
The red light will flash flash more slowly when the battery is being discharged.
After the battery is fully discharged, the base will then charge the batteries.
It should be noted that very few manufacturers of products that utilized NiCad batteries provided a "battery conditioning" feature.  Kensington was unique in this regard.  Battery conditioning allowed NiCad batteries to have a longer useful life.
Now maybe you can help me....  I lost my power supply that plugs into the USB connector.  If you have yours, can you tell me what the output voltage is and what the polarity is of the inner pin.  This will be marked right on the power supply base.
I plan to just get a generic power supply from Radio Shack, but I need the voltage value and polarity.  Until then, I can still use the mouse, but it won't charge.  FOr now, I'm just using standard AAA batteries.
Thanks.
[email protected]
Kensington... | Answered on Jan 26, 2010
I don't think the company supports this device with software updates probably not worth your time.
Kensington... | Answered on Aug 16, 2019
Power on keyboard with 5 seconds button on. Keyboard will start with LED slow two flash mode.
Go to Device menu and "Add a device". Select Keyboard.
On the UI keyboard, input "0000" (no enter), and touch "add".
Then on the physical keyboard, input "0000" + Enter.
It should make start connecting.
The UI changes into connecting view. But it already connected.
You can test with pushing "Windows Key" on the physical keyboard.
After connected, both LED on keyboard was automatically turned off. It is still working normally.
Kensington... | Answered on Jul 10, 2018
The mouse is too old and Kensington's website no longer supports it. Time to buy a different brand.
Kensington... | Answered on Jun 27, 2017
If it is a wireless mouse check the battery. Otherwise, replace the mouse. Check the cable to see if any critters have been chewing on it. My cat chomped the mouse cable and it ruined the motherboard
If you have unused USB ports on your PC you can plug in more than one mouse and they will both work.
Kensington StudioMouse Wireless Logo
1 questions posted
Top Kensington Computers & Internet Experts
Alun Cox
robert roberts
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kensington Computers & Internet
Most Popular Question
flashing red light kensington wireless
  • Computers & Internet
