20 Most Recent Kodak EasyShare CX7430 & EasyShare Printer Dock (Pack) Digital Camera Questions & Answers
Need new ink cartridge for
You don't say where you live but ink cartridges are available at places like BestBuy, Office Max, and online at amazon.com
1/13/2011 11:02:49 PM • Kodak EasyShare... • Answered on Jan 13, 2011
MEMORY CARD FORMATTING
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • 8/27/2010 8:02:21 PM • Kodak EasyShare... • Answered on Aug 27, 2010
    Sand in lens and shutter preventing it from
    Fixing a Lens Error on a Digital Camera
    This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
    The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
    A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
    Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
    The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
    Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
    Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
    Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
    Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
    Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
    Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
    Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
    Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
    5/12/2010 9:55:32 PM • Kodak EasyShare... • Answered on May 12, 2010
    Unable to print more photos
    I understand that you're experiencing printing problems.
    In order to clearly determine the fault description and the model of your KODAK printer dock is needed is needed. However here is the link to the online troubleshooting guide for the printer dock.
    http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
    If you need more help from me.
    Please Re-submit your question with the printer dock model and exact problem description.
    12/21/2009 11:25:53 AM • Kodak EasyShare... • Answered on Dec 21, 2009
    Internal memery is full well not us take pitchure cx7430 what to
    Here you go
    6/12/2009 2:47:58 PM • Kodak EasyShare... • Answered on Jun 12, 2009
    Memeory card full
    Greetings ashley 1980,
    This means that in order to take additional pictures, you need to use an external memory card. To clear up your internal memory, you would want to use the supplied usb cable to upload the pictures to your computer. Or you can delete these photos and this will also clear up memory space, but you would be able to retain the images.
    Thank you!
    Dorothy
    Go Ahead. Use Us.
    6/2/2009 5:12:56 PM • Kodak EasyShare... • Answered on Jun 02, 2009
    Cx7430 printer dock does not print a full pic., top is not printe
    Hi,Try the following sites to short out your problem…..
    http://uw713doc.sco.com/en/PR_admin/prntT.NoPrint.html
    http://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_5.htm
    http://www.smartcomputing.com/editorial/article.asp?article=articles/archive/r1101/04r01/04r01.asp&guid=
    Thanks
    12/4/2008 8:50:37 PM • Kodak EasyShare... • Answered on Dec 04, 2008
    Didgatial camera
    Internal memory on this camera is a small amount of space you can save photos without using an additional memory card. On this model it is 16 mb, which for a 4 megapixel camera is going to accomodate a limited amount of pictures. This would be more than likely about 10 pictures.
    I hope this helps.
    Dorothy
    Go Ahead. Use Us.
    7/31/2008 4:50:50 PM • Kodak EasyShare... • Answered on Jul 31, 2008
    3answers
    Memory Card Format Fail
    Hi I think its a compatibility issue. Try formatting it using your camera. else format it using Windows.
    7/31/2008 4:21:13 PM • Kodak EasyShare... • Answered on Jul 31, 2008
    3answers
    .MOV from Kodak M893 IS camera are not recognized by Quicktime
    The codec on mac does not recognise your file....try using a different player....vlc....gom player...mx player...instead of the one iTunes insist on chaining everyone to.
    4/24/2022 3:27:18 AM • Kodak EasyShare... • Answered on Apr 24, 2022
    Manual for easyshare camera c1450
    You may download the user guide at http://www.fixya.com/support/r13011856-lens_error and the extended user guide at http://www.fixya.com/support/r13011856-lens_error
    8/1/2018 7:25:03 PM • Kodak EasyShare... • Answered on Aug 01, 2018
    0answers
    Have a zig zag line through pictures on Kodak easy share. when I click on it, it says has been moved. how to get pictures back
    Move it back again. Did you do any editing in the computer ? If so, the camera will no longer recognise the images on the card.
    11/20/2017 7:26:56 PM • Kodak EasyShare... • Answered on Nov 20, 2017
    Kodak Z981 -- mode dial issue
    I have a Z981 myself. I just set my camera as you did (to "A") but did not experience the issue you mention? Just to be clear, remember that setting the camera to "A" means "Aperture priority", meaning that you can control the lens aperture (with the "jog dial" on the top of the camera) and the camera will automatically set the shutter speed to create a proper exposure. "A" does NOT mean automatic exposure control. You must use "P" (Programmed) mode to make the camera make all the decisions about shutter speed and lens aperture. I am including a web link to the User Guide for the Z981. You might want to revisit the Guide to make sure you are using the correct settings for your pictures. BTW, I like my Z981 quite a bit, especially the zoom. I've taken some great pictures with it. http://resources.kodak.com/support/pdf/en/manuals/urg01118/Z981_xUG_GLB_en.pdf
    9/28/2017 9:52:16 PM • Kodak EasyShare... • Answered on Sep 28, 2017
    What kind of charger does kodak af 3x take
    Surely this information is included in the technical specifications at the rear (probably) of the camera manual ?
    6/22/2016 11:28:18 PM • Kodak EasyShare... • Answered on Jun 22, 2016
    Kodak EasyShare CX7430 & EasyShare Printer Dock (Pack) Digital Camera Logo
    Popular Tags
    13 questions posted
    Top Kodak Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
    View Most Popular
    EasyShare Kodak
    • EasyShare Kodak
    Most Popular Question
    need new ink cartridge
    • Cameras
