20 Most Recent
Maytag MER5530 Electric Kitchen Range Questions & Answers
All of the sudden our
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Why does the large front burner stay on high heat
Sorry to read about your problem, I hope this helps you out.
you have a defective burner control valve.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
I have a mer5730aaw my
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power
off to the range at the circuit breaker). It is very important that the power
to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from
the ERC
4. Make sure there are no lose wires, or anything else that may cause a short
when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
After self clean cycle completed........oven not
Hi
These kinds of issues are usually caused in ovens if a self cleaning cycle is used after a long time. The issue can either be a bad door switch/lock assembly or the oven temp. sensor itself that has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
My oven works,but it won't get up to the right
check your element when you turn on your oven also you can do a continuity test to assure that there are no break spots in the element the next thing to check would be your oven tempreture sensor usually small metal rod along top with two wires hooked through the back wall of the oven if you look in your manual should give you for a spec and you can do an ohms test on the sensor if the sensor fails from what the spec states replace the sensor when checking the element make sure the element glows red other then this you would have to go into the back panel of your oven and do some power tests and comparing that to your tech sheet that the write amount of power is going to the right places check element and temp sensor first please remember to rank how this opinion has helped in your appliance situation and if there are any futher questions please message me back have a great day
rickead1
Oven & broiler not heating on our Maytag
May be the heating coil is bust?
The control panel is in parallel usually so as long as the controls are getting power they will turn on. But if the coil is gone you wont get heat. If you want to try fixing it, you may need a multimeter, or a continuity tester.
My oven won't work on bake but everything else is operational
Most likely have a bad heating element. Check for continuity in the element. Make sure to trip the breaker or unplug the unit before removing the element. 120 volts still run through the element even though it is not turned on. Takes 240 volts to make it glow red.
Code F7 appeared during oven use
You have/had a stuck keypad. If it happens again just push all pads at random to try and unstick it. If it gets to be a nuisance replace the keypad membrane.
Bake element in oven not working
Unplug the range. Open the control panel and unplug the ribbon connector to the control. Plug the range back in. If the beep continues replace the control. If it does not continue replace the touchpad.
