FixYa.com
Nikon LS-9000 Film Scanner
All Products > Nikon > Scanners
Problems with Nikon LS-9000 Film Scanner?
Search inside Nikon LS-9000 Film Scanner Knowledgebase
Troubleshooting and Support
Solved Problems for Nikon LS-9000 Film Scanner RSS Feed Post a New Problem
nikon coolscan 9000
rapid blink of lights does not recognize any film holders
1 Solution
How to Clean a Scanner?
1 Solution
"A HI SPEED USB device plugged into a...
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea?
1 Solution
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
I unhooked by scanner ro rearrange some...
I unhooked by scanner ro rearrange some equipment and forgot how it was connected. I think it should be as follows:...
1 Solution
not support window xp
acer scan 620st bit suport window xp
1 Solution
Microtek artix scan 120tf
My microtek negative scans are coming out with a very strong cyan bias, and i consistently get a light cyan strip all...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Nikon LS-9000 Film Scanner RSS Feed Post a New Problem
batch scans using the 120/220 strip film...
I try to use the glass holder to scan as many as 4  6x4.5 transparencies and can not get the images to line up when...
Post a Solution
it will not recognize the film holders no...
nikon 9000 will not recognize the film holders
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformMac, PC
TypeFilm Scanner (35 mm)
InterfaceIEEE 1394 Firewire
Optical Resolution4000 dpi
Max. Resolution (Hardware)4000 x 4000 dpi
Max. Color Depth16-bit (64K Colors)
Technical Features
Form FactorDesktop
Scan Element TypeCCD
Light SourceRGB LED
Input TypeColor
Film Scanning Capabilities35mm Slides · 35mm Filmstrip · Positive Film · Negative Film · Color Film · Monochrome Film
Optical Density4.8 Dmax
Preview Speed13 Sec
Media
Supported Media TypePositive And Negative · 35 mm Slides · 35 mm Film · Film · Slides · Negatives
Media Loading MethodManual Load
Max. Supported Media Size56 x 83 mm
System Requirements
Operating SystemApple MacOS 9 · Apple MacOS X · Microsoft Windows XP Home Edition · Microsoft Windows XP Professional · Microsoft Windows 98 SE · Microsoft Windows ME · Microsoft Windows 2000 Professional
Dimensions
Depth19.6 in.
Height7.95 in.
Width9.8 in.
Weight19.8 lb.
Nikon Contact Information
Main support number1-800-NIKON-UX , 1-800-NIKON-US
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
