20 Most Recent
Logitech Cordless Wireless Optical Mouse for Notebooks 931006-0403 Questions & Answers
Wireless mouse settings
If this is a PC notebook rather than a Mac then go to Settings > Control Panel > Mouse and Pointing Devices and tweak the settings. Be sure you have run the Logitech driver installation program first.
8/12/2014 9:09:39 AM •
Logitech...
Answered
on Aug 12, 2014
What reciever???the modem???
The receiver is the item that is stuck into the port on the computer that the cordless mouse communicates with. If it is not in the port, the mouse cannot send signals to it. The mouse is considered to be the sender. See picture of receiver above.
5/15/2014 1:22:34 PM •
Logitech...
Answered
on May 15, 2014
I cannot pan with the mouse in Autocad or Revit.
Go to START > CONTROL PANEL > MOUSE ..... Here you will find the Logitech settings. On the BUTTONS tab, you will see a diagram that numbers the buttons on the mouse as well as a table that shows what each button is assigned to. In this table, double click the number assigned to the mouse wheel (usually button 3) and reassign the wheel to MIDDLE BUTTON. This should restore your Autocad pans.
2/25/2014 4:21:13 AM •
Logitech...
Answered
on Feb 25, 2014
Bought a logitech wireless mouse..cannot get it to
If you go to logitech.com/support and type in the type of mouse you have they will give you downloads so you can choose the vista 32 bit software. Its nice software and the mouse should run fine.
1/8/2010 3:06:34 AM •
Logitech...
Answered
on Jan 08, 2010
Mouse freezes
Try reinstalling the CD software program.
Normal
0
Disconnecting the Mouse Receiver from the
USB port and reinstall the CD software program. When
the program asks you to connect the Mouse Receiver to the USB
port, do so and it should work.
Hope this helps. Bud
1/20/2009 6:59:23 PM •
Logitech...
Answered
on Jan 20, 2009
It stopped working
NO sync required.
But the batteries may have died out.
open the lid under the mouse and you can replace the bateries
And also does the system give a pop up "USB device Connected" when you plug the transmittter to the back of the computer?
4/22/2008 2:25:18 AM •
Logitech...
Answered
on Apr 22, 2008
Logitech wireless combo mouse keyboard mk220
support through bluetooth
• Check the orientation of the batteries inside the keyboard and mouse, or replace the batteries.
• Is the USB receiver securely plugged into a computer USB port? Try moving the USB receiver to a USB port closer to the keyboard and mouse.
• If the USB receiver is plugged into a USB hub, try plugging it directly into your computer.
• Remove any metal object between the receiver and the keyboard/mouse that may interfere with reception. Try using the mouse on a different surface.
• Restart the computer.
• If these suggestions don't work, download the Reconnection Utility from
http://www.logitech.com/connect_utility.
2/28/2024 3:07:39 PM •
Logitech...
Answered
on Feb 28, 2024
How i can connect my logitech wireless mouse EN60950 to the laptop
Unfortunately, EN 60950 is not a Logitech model number. It indicates that the mouse (or other electronic product) was tested and met the European IEC 60950 standard. Here's a copy of a Logitech EN60950 certificate:
https://www.logitech.com/images/pdf/compliance/AGY-700-018651.001_AGY%20CERT%20CB%20HS%20A00086%20BAER%20CI%20(GGEC)_EUROPE.pdf .
Logitech sells several different wireless mice types. Some connect to Bluetooth only. Some connect with a specific USB wireless transmitter/receiver. The dongle is small enough to fit inside the mouse's battery compartment or stay in a USB port when the laptop is moved. (Older Logitech devices used the Unifying USB wi-fi adapter; new ones use the Bolt adapter.) A few models can be used with both Bluetooth and one of the wireless adapters. These can connect to two or more devices and then a single button switches between devices.
Please try to find the actual model of the mouse to get the correct information for connecting the mouse. Logitech support may be able to sell you the USB dongle if they have the correct one in stock.
I hope this helps.
12/8/2023 11:47:00 PM •
Logitech...
Answered
on Dec 08, 2023
How do I add format to my logitech 650I downloaded from my old logitech to my new logitech and it doesn't have the format button on it
It sounds like you are trying to use the same formatting settings on your new Logitech keyboard that you had on your old Logitech keyboard, but the formatting button is not present on the new keyboard.
To add the formatting button to your new Logitech keyboard, you will need to do the following:
- Open the Logitech Options software. This software allows you to customize the settings and functionality of your Logitech keyboard.
- Select the "Buttons" tab. This will allow you to customize the buttons on your keyboard.
- Find the formatting button that you want to add. Depending on the model of your keyboard, you may have the option to add a variety of formatting buttons, such as bold, italic, and underline.
- Assign a function to the button. To add the formatting button to your keyboard, you will need to assign a function to it. Click on the button and then select the formatting function that you want to use.
- Save the changes. Once you have added the formatting button and assigned a function to it, click the "Apply" button to save the changes.
I hope this helps! Let me know if you have any other questions.
1/2/2023 12:12:25 AM •
Logitech...
Answered
on Jan 02, 2023
