20 Most Recent
Maytag MGR5875QDS Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
I have a 5 yr
Just take out the motor and hot wire it to see if it runs. If it does the issue is with the power feed in your range.
Check fan for free spin. If the bearings are full of gunk it may not have enough torque to overcome it. Clean and lube both motor bearings and see what happens.
9/9/2017 8:38:34 PM •
Maytag...
Answered
on Sep 09, 2017
Maytag mgr5750 convection fan not working
check fan connection for voltage during operation requested. if no voltage then it is the control. if there is voltage then it is the fan itself. hope that helped and thank you for reading this.
10/10/2014 8:12:16 PM •
Maytag...
Answered
on Oct 10, 2014
I have a error code of 596 6ATH and cant seen to
The error your range is displaying is actually "SABBATH", which is Sabbath Mode. This enables the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question uder is correct, the instructions for Sabbath mode are listed on page 14 of your owner's manual. To cancel Sabbath Mode you press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please post back with your correct MODEL NUMBER (if different from the one I provided) and let me know. I hope this helps you.
5/1/2010 10:59:22 PM •
Maytag...
Answered
on May 01, 2010
Hook up oven door on maytag gas range
You likely need to lock the hinge in open position to do it. Either there is a small lever on the hinge itself you need to flip when the hinge is in the open position or there is a hole in the hinge, where you need to insert a steel pin (you can use screws, but they bend somewhat ;)) to hold the hinge open
3/13/2010 7:32:03 AM •
Maytag...
Answered
on Mar 13, 2010
I have a maytag Gas
I've had the same problem with mine...There's a kit to go from Natural to Propane...But I haven't had any luck trying to find one to go the other way.
I also had an appliance repairman, said that he could handle this problem...Tried three different businesses...and no one ever shows up.
All that's really neccessary is to replace the ilets (different sizes for Natural Gas/Propane). No one seems to be able to come up with the Ilets though. Apparently all the stoves come, Natural Gas ready, and you have to convert them to Propane.
Maytag offers the ilets (about $25.00 each, and that's just for the stove top) there's another procedure in the owner manual that explains how to convert the oven.
Let me know how this works out for you; I've considered selling the Propane stove and just buying another stove.
HTH,
Mike...
12/12/2009 7:47:41 PM •
Maytag...
Answered
on Dec 12, 2009
I have a gas range and I think the burners are
ther should be 2 sets of brass nozzles for the burners, make sure that the correct ones are installed, ie natural gas or propane. they have a different injector size for each.
12/2/2009 1:04:46 AM •
Maytag...
Answered
on Dec 02, 2009
When I select bake on my gas oven and select 375
Hi, The most common fix is a new oven ignitor. The ignitors go out and will not open the gas valve. Remove the floor panel inside the oven and you will be able to see the ignitor.
Please let me know if I can assist you further.
Vic
7/16/2009 2:33:35 AM •
Maytag...
Answered
on Jul 16, 2009
Stove ignitor does not light burner. How to fix ?
This may sound silly and I know your stove is gas, but is your stove plugged into a power outlet on the wall? Some older stoves had the igniters powered from a wall socket so had to be 'plugged in' and others are powered by replaceable batteries, (AA's or AAA's), with the pack being mounted low down on the front, near one of the front feet. If it is a battery type try changing the battery for a new one. Sometimes the fix is that easy.
My maytag gemini oven keypad (numbers only) stopped working.
If the keypad on your Maytag Gemini oven (numbers only) has stopped working, there are a few troubleshooting steps you can try:
- Power cycle the oven: Turn off the oven by unplugging it from the power source or by switching off the circuit breaker. Leave it powered off for a few minutes, and then plug it back in or switch the circuit breaker back on. This can sometimes reset the keypad and resolve temporary issues.
- Check for physical damage: Inspect the keypad for any physical damage, such as cracks or signs of wear. If you notice any damage, it may be causing the keypad malfunction. In such cases, the keypad might need to be replaced.
- Clean the keypad: Over time, dirt, grease, or food particles can accumulate on the keypad, which can interfere with its functioning. Use a soft, damp cloth to gently clean the keypad. Avoid using harsh chemicals or excessive moisture that could damage the keypad.
- Test the oven's other functions: Check if other functions of the oven are working properly, such as the temperature controls and other buttons. If only the numeric keypad is affected, it could indicate a specific issue with that part of the keypad or the underlying circuitry.
- Contact Maytag customer support: If the above steps do not resolve the issue, it is advisable to contact Maytag customer support or schedule a service appointment with a qualified technician. They will be able to provide further guidance and assistance in diagnosing and fixing the problem.
I changed my Maytag over to lp and the oven and broiler don't get propane to it it glows but no flam what's wrong
If you've converted your Maytag oven to LP (propane) and you're experiencing issues with the oven and broiler not receiving propane and not producing a flame, there could be a few possible causes:
- Gas supply: Ensure that the propane supply to the oven is turned on and the gas valve is fully open. Check that the propane tank is properly connected and that there is sufficient propane in the tank. If the tank is low or empty, it may need to be refilled.
- Incorrect conversion: Double-check that the conversion from natural gas to LP was done correctly. Verify that the conversion orifices have been installed in the correct locations and that the air adjustment shutters or plates have been adjusted according to the manufacturer's instructions. Improper conversion can result in inadequate gas flow and a lack of flame.
- Clogged orifices: It's possible that the orifices, which control the flow of gas, have become clogged with debris or residue during the conversion process. Clean the orifices using a small brush or a compressed air canister specifically designed for cleaning gas orifices.
- Gas pressure: LP gas operates at a higher pressure than natural gas. Ensure that the pressure regulator on the oven has been adjusted or replaced to accommodate LP gas. If the regulator is not properly set for LP gas, it may not deliver the correct pressure for proper combustion.
- Faulty ignition system: If the oven and broiler are glowing but not producing a flame, there may be an issue with the ignition system. Check the igniter for any signs of damage or wear. A faulty igniter may not generate enough heat to ignite the propane. Consider replacing the igniter if necessary.
If you've checked these potential issues and the problem persists, it may be best to contact a qualified appliance technician or the manufacturer's customer support for further assistance. They can provide specific troubleshooting steps or arrange for a service visit to diagnose and resolve the issue with your Maytag oven.
Maytag Gemini, double oven electric. Replaced bottom element, replaced thermal sensor and tested power. It still won't heat up. WHY?
There are several potential reasons why your Maytag Gemini double oven electric range is still not heating up after replacing the bottom element and thermal sensor and testing the power. Some possibilities include:
- The wiring or control board may be faulty and preventing the oven from heating up.
- The upper heating element or broil element may also be faulty and need to be replaced.
- The oven may not be calibrated properly, which could cause it to not heat up correctly.
- There may be a problem with the oven's door latch or switch, which could prevent it from heating up.
