20 Most Recent
Augen E-Go OE-A736 AKARM ARM926-AK7802 248MHz 64MB 2GB 7" Netboo Questions & Answers
I have a Augen Genbook I have been charging for about 24 hrs and it will not com one what do I need thank you
Lots of things to try.
- Remove the battery plug it in and try to power on.
- Remove the battery and charging cable, hold the power button for about 10 seconds then replace battery and charging cable and try to power on.
- replace the charging cable and/or battery
- Do you hear any sounds when you try to power on?
- Anymore details would help a lot power issues can be as simple as charging cable not connected properly to system board issues.
I need a ip adress for my 7 inch Augenus computer
so that is not really a questions -- do you need to know it's address on the network? Do you need to know the IP from your ISP that you are connected to? Or do you need to know the IP from a SIM card that you are using to connect.
You could also add the why if you don't know the other information -- someone should be able to tell you what address you need and how to get it.
Hope that helps. cheers, Jon.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
