On an MSI 915GVM3-V motherboard, eng_m_yehia?
http://www.msi.com/product/mb/915GVM3-V.htmlOn the above page hover your mouse cursor on - Downloads(Overview/Specifications/Download/Support/Where to Buy)In the drop down list click on - ManualScroll down a little. At the right side of the file listing, and under the sub-heading - Download, left-click right on the blue - M7223v1.0.zipThe next page wants you to click on a country nearest yours.Me? I click on US.A small window will come up on the right.Opening M7223v1.0.zipMake sure the small circle to the left of - Save File, has a green dot in it. If not left-click on the empty small circle to the left of - Save File.Now go below in the small window, and left-click on OK.A small window will come up on the left.IN the top of this window tells you where the file will download to.Suggest you write it down.The wording may have Desktop, or My Documents, or Downloads, in it.(This is for Win XP. IF you have Vista, or Win 7 it is different. Post in a Comment if so)Desktop: The file (M7223v1.0.zip) name will be on your desktop screen, and next to a yellow folder icon, with a zipper on it.My Documents: Click on Start, then on My DocumentsDownloads: Click on Start, then My Documents. DOUBLE-click on Downloads.When you see the file name DOUBLE-click on it.The next scenario differs;You may have a screen that has Unzip on the right side. If so left-click on Unzip.You may just have a screen where you go to the far left side, and left-click on Extract all files.Left-click on Extract all files.In the next three small windows that come up;Click on Next, Next, and Finish.You will now see a red Adobe PDF icon, and M7223v1.0 next to it.DOUBLE-click right on it.You are now looking at a PDF file version, of the motherboard manual, for an MSI 915GVM3-V motherboard.I wanted you to have the motherboard manual for the future.Now, Jumper J1 not connected;Nope, don't see it.Would this be a reference to jumper JFP1? The Front Panel header, and the 1st jumper block?[ The plastic front of your computer is the Front Panel.The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header. In this case there are two headers ]If so I got yer back, eng_m_yehia.JFP1 is to the right of the BIOS chipset. (Which is below the SATA 2 port, and the CMOS battery )JFP1 is where the;1) Power On switch connects2) Power On LED light connects. (MAY connect to JFP2. Read on )3) Reset switch connects. (IF, a Reset switch is used. No Reset button? No Reset switch )4) HarDDrive activity LED light connects. Looking at the motherboard installed in the computer;Processor to the top, Ram Memory to the right, white PCI slots (3) at the bottom.The JFP1 header is at the right bottom edge of the motherboard, to the right of the BIOS chipset, and is situated Vertically.Has two columns of contact pins. Starting at the BOTTOM Right side, going UP;Pins 1, 3, 5, 7, and 9.Starting at the BOTTOM Left side, going UP;Pins 2, 4, 6, and 8. There is NO Pin 10, just a blank spot.A) Pins 1 and 3 are for the HarDDrive activity LED light.Pin 1 is for the Positive ( + ) wire. IF the HDD activity LED is dim, when the harddrive is operating, switch the wires around.B) Pins 5 and 7 are for the Reset switch. IF, a Reset switch is used.C) Pin 9 is N/C. Not Connected. Not used. This is for the factory.D) Pins 2 and 4 are for the Power On LED light.Pin 2 is for the Positive ( + ) wire. If the LED is dim when the computer is on, switch the wires around.E) Pins 6 and 8 are for the Power On switch.A note about the Power On LED light, and wires.For a Power On LED light that has TWO wires, use JFP1.If it has THREE wires, use JFP2.Some Power On LED lights had/have dual colors. In the older computers it usually was Green, and Yellow.Yellow meant you were in Normal mode, and Green meant Turbo mode.A bunch of cr@p really. When in turbo mode, the computer was operating at it's fullest. In the other mode, it was being slowed down, below the normal output of the computer.For additional questions please post in a Comment.Regards,joecoolvette
