20 Most Recent
Mustek GSmart S50 Digital Camera Questions & Answers
try first this ..for to see if the adapter/charger is to blame ..or the camera has a issue or it is the charger plug ...
This camera has the possibility to be charged from a computer in the usb mode...so ..connect the camera to the computer with the data cable ...than after you closed all the autoplay and whatever might start on computer ..click on the icon in the tray system ..and select remove ...but leave the camera in ...and on ...and look if it charging...anyway in the usb mode it is charging and may be a way to use it ..and if it does..it means that the charger is burned or the plug do not makes contact well..and either clean or change the plug ..after you measure the charger and see its working ...This way you eliminate them on eby one ...if it charges with the usb cable and powers on ..measn it is ok ..but a issue is with the charger ..and if this seasm to be ok when measured or tried with aanoter device ..than the only thing that remains is teh charger plug ..and you will have to change it ..
But , if with the usb cable r ..leaved on ....and off at the time about an hour or two ...and still not powers on ..it is probably another thing much worse ..the board or ..the battery ..and you have to analyze if it 's worth repairing ..
Mustek GSmart S50 Digital Camera replacement
Hello David,
This camera has a built in Lithium-Polymer battery. In general these batteries are custom made for the camera, so replacing it with other battery types is not a very good ideea. My advice is to go to a dealer and purchase an original battery for your camera. Unfortunately the web does not give the battery type for this camera, you really need to ask a dealer.
I have no way to charge my mustek dv520t
As it is now 12 years old, I doubt if a suitable charger is still available, quite apart from the condition of the batteries after all this time. If I were you, I should bite the bullet and replace it with a more up-to-date model.
I have a problem, trying
Camera software can be set to download pictures from the camera and then delete them from the camera. Whilst this process is easy to do, the reverse is not so easy.
Most cameras connect to your computer and are treated like a drive on your computer. You can click on the photos you want copied back to the camera, right click on them and choose Send To. The last drive letter is usually your camera. If you have a built in card reader you will need to work out what the drive letter is for the card and send to that instead.
Use Windows key combinations to select multiples like holding down Ctrl and clicking to select in batches and shift click to select a whole range from the first to the last.
I need a user manual
You may please download the User Guide for your
from this location on the manufacturer's website.
I will appreciate your feedback and positive rating for this free solution.
